Anyone did fixed their own intake leak?
Anyone here fixed their own intake leak?
I'm putting my motor back together and I'm wondering if they did something else with the gasket or used a different one to fix the problem. I had the intake leak once before and they fixed it under the warrantee.
Re: Anyone did fixed their own intake leak?
match on intake
RTV makes a wall
http://www.worldisround.com/articles/18770/photo62.html
What does the slit do? Do you lay a bead of silicone in there? Is that how they fix it?
Niether I nor the previous owner of the block had anyintake manifold leaks
When I put my motor back together I put a nice thick bead on that part of the intake, along with using the gasket. The stuff I used was that gasket maker stuff from permatx that comes in a aerisol type can of a caulk gun style tube. So far after 2000 miles no issues.
I did something similar to what Trey mentioned. I scored the areas of the block and the manifold where the RTV goes with the corner of a file. Basically I made a bunch of deep X's all over the place. It gives the RTV something to 'bite'. Without doing something like this, those areas will still be smooth and there'll be more of a possibilty that the RTV won't stick well and you're back in the same leaky boat.
Everything I read says to lay a 1/4 in. bead of that caulk type sealant. Doesn't that crap oooz into the motor?
No leaks, no problems.. did the leak fix many, many moons ago.
Originally posted by SinisterSS
Let the silicone cure for over 24 hours before you fire up the motor. Allows it to cure before oil starts getting thrown around inside.
Thanks for the input all.
I thought about "toothing" the rails myself but, damn, I hate to start making fine metal shavings when the intake is off. I just took my chances on having another leak. I'd rather take my chances on having it leak again than having a cam bearing go.
That's just me though.
Jeff D.
Jeff D.
