a little overheating question
Old Sep 23, 2003 | 01:09 AM
tealman92's Avatar
okay heres the platform 1993 pontiac trans am gt 88,000 miles on it lt1 auto. the problem is that when I cruise around with the air on ,on the freeway or the styreets the temp stays around 235 . heres what is done buy to the car it has a hypertech fan switch that is still working so its not the fans it has a 160 t-stat thats brand new just replaced today to try to remedy the problem
. it has new fluid and was flushed the air dam is in perfect condition and the water pump is working like it should I just dont understand how my car can go from working like I want one day( staying a 170 all day long no mater the temp outside with or without air) to just overheating the next. Everything is perfect on the car all stock un touched except for the fan switch and the t-stat so any help will he great. I dont want to change the radiator to a 3 core or b-cool so help please
Old Sep 23, 2003 | 01:31 AM
NewbieWar's Avatar
any bubbles in ur radiator? those can heat quite fast
Old Sep 23, 2003 | 01:34 AM
Revenant's Avatar
Did you bleed the cooling system? That reverse flow has a bad habit of trapping air and needs to be bled after a flush either through the bleeder valve or by removing the radiator cap (engine cool) and allowing the engine to idle until warm.
Old Sep 23, 2003 | 02:37 PM
tealman92's Avatar
Yeah I blead the system after the flush with all 3 bleeders im gonna drive the car with the ac off today to see if the temp stays at 180 like its suppose to with the fan switch because its been a little hotter than normal here in socal and ill also check the t-stat i got from auto zone to see if its really working thanks so far more suggestions would be appresiated
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
