A little cloud of smoke
Old Dec 4, 2006 | 09:33 AM
drifter60060's Avatar
Ok guys. I just had the engine in my 94 Z replaced, LT1 longblock. Car runs great now. I just have this one problem: when I punch it and go to passing gear I get a puff of smoke out of the exhaust. I cannot tell if it's blue or white, it's not big enough to really tell. I just had my pcm scanned, no trouble codes, no warning lights, nothing. I do have a strong smell of fuel as the car idles though. Car is completely stock with no mods. I don't know if the charcoal canister needs to be replaced or what. Any help would be greatly appreciated.
Old Dec 4, 2006 | 07:58 PM
roguedriver's Avatar
Sounds like it's a tad on the rich side at WOT. Any way you can get it on a wideband or maybe make a dyno pull on it to see what your A/F is?
Ken R.
Old Dec 5, 2006 | 02:07 PM
I'll have to find out where a shop is that has a dyno around here. What do you think about the fuel smell? Need a new canister or fuel pressure check needed?
Old Dec 5, 2006 | 05:52 PM
MeanGreen97Z's Avatar
Check for fuel leaks around the canister or lines. Check to make sure the fuel lines are all the way down on the fittings on the fuel rail.
Old Dec 5, 2006 | 06:27 PM
VinceTrifecta's Avatar
How long did your fuel injectors sit between the engine swap? Fuel injectors don't like to sit around.
Old Dec 5, 2006 | 07:04 PM
lt1 kenobi's Avatar
Check what others have said, but I'd venture to say that you are probably just running a little rich.. stock tunes tend to be that way...
Old Dec 6, 2006 | 10:05 AM
'Preciate the help guys. I plan to get out there today and check a few things out.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Boss002
Jul 9, 2015 03:33 PM
