HELP!!! fuel rail wont hold a prime please read
Old Dec 5, 2006 | 03:06 PM
96badbird's Avatar
okay as soon as the fuel pump quits running i loose the prime on the fuel rail. ive change the fuel pump, the regulator, changed the relay, checked the injectors none of which seem to be leaking and there are no visible fuel leaks anywhere.. i have no idea why this is happening. if anyone has experinced anything like this or know what the hell is goin please please please help me out.
Old Dec 5, 2006 | 03:16 PM
evilundisguised's Avatar
Can you easily check the hose connections inside the fuel tank?
Old Dec 5, 2006 | 03:27 PM
grammerman's Avatar
If you've changed the pump and the connections are sealed up then you may have some debris in your system. If a small piece of debris lodges in the regulator seat the pressure will bleed down quickly. Might try disconnecting the fuel lines and using compressed air and solvent to flush the supply line and fuel rail.
Later, Michael
Old Dec 5, 2006 | 04:34 PM
What fuel pump did you put in? The Walbro's seem a bit sensitive to getting dirt in the check valve. Was it a problem before the Aeromotive AFPR - a not very reliable piece?
Old Dec 5, 2006 | 06:29 PM
96badbird's Avatar
this was a problem before i changed the regulator and before i changed the pump.
Old Dec 5, 2006 | 07:01 PM
Meen95z's Avatar
Well I have a aeromotive regulator and the pressure bleeds instantly and alot of people have problems with them because of poor machining internally.. And if you dont have one of those maybe where the shrader valve connects to fuel rail.. Possible leak, mine did just from screwing the fuel line for nitrous on and off a few times..
Old Dec 5, 2006 | 09:56 PM
96badbird's Avatar
i do have an aeromotive regulator i wonder if thats the problem
Old Dec 5, 2006 | 10:30 PM
blackztpi's Avatar
usually if the regulator goes bad, you'll get an *** load of fuel into the intake. this sounds like a fuel pump check valve being bad, but it must not be if you replaced it. are you positive you';re injectors are leaking? i'd have them pressure trested. nothing else can cause that kind of a fall out. if it was a fuel line, your pressure at the fuel rail would be substantially lower than normal. it's got to be regulator, pump, injectors.
Old Dec 6, 2006 | 09:13 AM
96badbird's Avatar
thats what i was thinking i think im going to have them professionaly checked
Old Dec 6, 2006 | 01:49 PM
blown383's Avatar
How did you connect the fuel pump to the hard lines on the hanger?
-B
HectorM52
Jul 30, 2017 11:46 AM
4586
Feb 13, 2015 09:16 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
