list of what my 383 is gonna have....please tell me it's worth it????
Old Aug 25, 2005 | 11:54 AM
  #16
JustNO's Avatar
Re: list of what my 383 is gonna have....please tell me it's worth it????
Originally Posted by RUFST
okay look this quote over which is similiar but with a diff. company RPM in Nashville and tell me if it's better for the value...b/c the first quote at the top...the guy said would not last as long meaning this one is not as strong as his but it is a grand cheaper
383 LT1 Built for 150 nitrous
-Eagle 4340 steel 3.750 Crankshaft
-Comp Cams Hydraulic Lifters
-Eagle H beam 6.000'' Connecting Rods
-Mahle Pistons
-Mahle Rings
-Comp Cams Hydraulic Roller Camshaft
-GM HD Timing Set
-Felpro Head Gaskets
-AFR cnc ported LT4 heads -Chromoly Pushrods
-Comp narrow 1.6 Rockers
-Meling High Volume Oil Pump
-Clevite Rod Bearings
-Clevite Cam Bearings
-ARP Main Studs
-ARP Head Studs
-Felpro Gasket and Seal Package
-Fully Machined w/Deck Plates
-Blueprint Assembly
-high volume fuel pump
-Port Matched LT4 Intake
-42# Injectors
-Remove and Reinstall Engine
-Dyno & Tune
-SLP or Hooker Headers
-Magnaflow Cat-Back
-Meziere water pump
-NGK Spark Plugs
-Custom Spark Plug Wires
-Walbro or Accel Fuel Pump
-58mm throttle body
$10,500
including AFR heads huh? Its very cheap!!
Old Aug 25, 2005 | 02:50 PM
  #17
RUFST's Avatar
that's the quote he gave me so that's what he would be building.....so the second quote would be a better setup and cheaper right?
but i know the eagle crank and the mahle pistons is not as strong as the dragonslayer and diamond pistons correct??? that's what i was told by the other guy that wants to build it (the first quote at the first of the message)
Old Aug 25, 2005 | 03:25 PM
  #18
JustNO's Avatar
something wrong with your second quote.. Its too cheap
Old Aug 25, 2005 | 04:31 PM
  #19
1racerdude's Avatar
What ya have on your second quote is enough to hold 1,000HP how much stronger do ya need?
Old Aug 26, 2005 | 10:31 AM
  #20
RUFST's Avatar
well i was just making sure my second quote was going to be a good strong motor and not just using per say cheap parts.....
has anyone ever had anything built by RPM one of our sponsors on here outta Nashville, b/c that's where this second quote is coming from
btw anyone have any pics or vids of their 383's i can compare to and how much it cost them and what kind of numbers you all are putting down?
thanks
Old Aug 26, 2005 | 11:42 PM
  #21
MachinistOne's Avatar
Mahle pistons are great.
What compression is he going for?
What are the cam specs?
You don't need a HV oil pump, just a M55A
There is no reason why that 2nd motor will not last as long as the first....
Old Aug 27, 2005 | 05:20 PM
  #22
RUFST's Avatar
i'm not sure what compression or cam specs yet we've just been laying some stuff out there...i will find out from him on mon. tho and write back so you guys can dig through it and tell me what you think.....b/c obovisly i think highly of all of your or most of you guys comments on here are very true and i appreciate it b/c this is a big investment as you all know that's done it
see i don't even know the diff. b/t a HV oil pump and a M55A so you'd have to explain....alot cheaper but still get the job done sort of thing?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
