LINGENFELTER acceleration vid...
well.. LPE, Cam Motion, Isky, Eagle, Compstar, SLP, Spohn, NGK, Taylor, MSD (damn... feel like I'm in NASCAR), Smith Brothers, Walbro, Hooker, JE, Mezier, Cloyes, Canton and Crane...
Yeah you can't see anything. Just use your imagination. You could probably turn up the contrast full blast on your monitor and see something? It's a 10 - 115mph punch on 3.73 gears and Nittos shifting at 7100rpm. The reason why you see the shift light so much is because it has a 6200 pill:
http://youtube.com/watch?v=vq4Ai9b8uiI
And here's documentation on how driveable this thing is. It's unreal compared to my stock block/ LPE heads/ GM847 cam. I virtually had to eliminate ever using 6th gear (with the 3.73's at least). This vid was while in 5th:
http://youtube.com/watch?v=8Z84KlQXtNM
maybe later. i got stopped about 1/2 hour before that vid was shot.
cop was the nicest one i've ever ran into. i was doing 65 in a 50 while passing a car and he let me go. even made a comment on how loud the exhaust was, but then stated, "that's just how these cars are..."
just wow...
just wow...
thanks. it's a combination of being solid roller and the CID. The cam is an off the shelf mild grind. Same one Jordon Musser used in his 401 LT1 solid roller.
Yeah how did yours do yesterday? SPUTTER HICCUP FART BLAP FIZZLE....
That's what I thought......
You think? I mean you would know, right? I dunno.. maybe it might have something to do with the fact that the car was going 55mph when shifting into 2nd gear, or maybe I did a burnout before hand? Maybe I laid some traction compound down first? Oh.. it could've had something to do with it being a 7% downhill grade. Man.. it's just tough to say...
Just worry about your turd and I'll worry about how much or little traction mine has. It's slow. Why not come down here and make some easy money?
Good first video, but in the second one i have a question. What was that you said? "They see me rolling, they be hating". Can I use that qoute in my sig. Brian?
In that case.. if you're actually trying to be cordial instead of that usual indirect flaming crap then by all means I'll indulge...
Yes that's what I said and it's not coined by me so use away. I'm not really interested in the MT's because the wear rating is horrible and they're bloody expensive. The Nittos do just fine for my needs. Once I go to the track then I'll use the ET Streets and if that's not enough I'll go for something more aggressive.
