limits of the stock fuel lines
Old Aug 11, 2005 | 01:44 AM
Miles-'s Avatar
just as the title says what is the limit for the stock lines? the car is 383, with a t-trim and will be around 540 to the wheels. I am looking at the racetronix kit, with 50lbs injectors? any input is appreciated
thanks
Old Aug 11, 2005 | 09:07 AM
Re: limits of the stock fuel lines
Although I run braided S/S fuel lines, they are essentially the same size as the stock supply line (-6AN vs. 3/8") and only slightly larger on the return line (-6AN vs. 5/16"). I'm making 800 flywheel HP on a 300-shot of dry nitrous, with an 0.53#/HR/HP BSFC. Fuel system is dual Bosch 205 LPH pumps, running in parallel, and 78#/HR injectors at 58psi. The stock-sized fuel lines seem more than adequate at that level. I do have the fuel rails "split" to run in parallel, rather than in series.
Old Aug 11, 2005 | 10:10 AM
engineermike's Avatar
I'm running totally stock plastic lines and routing with about 850 fwhp and no problems.
Old Aug 12, 2005 | 01:19 AM
Miles-'s Avatar
Thanks for the replies, that is good to know
Old Aug 12, 2005 | 07:25 PM
Racetronix's Avatar
thanks
Consider the Siemens L107.
The Delphi 17113738 does not tune easily with a LT1 ECM/PCM.
HectorM52
Jul 30, 2017 11:46 AM
Jan 23, 2015 01:13 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
