limit of 8740 connecting rod bolts
Old Mar 23, 2009 | 11:42 PM
94sc383's Avatar
has anyone broken/damaged these rod bolts that come with eagle rods? i've heard there junk and would like to hear stories of them failing.
Old Mar 24, 2009 | 06:16 AM
87bandit's Avatar
they're an ARP bolt, not the best but not garbage I'd say
Old Mar 25, 2009 | 01:15 PM
marshall93z's Avatar
Better than stock.
Old Mar 25, 2009 | 04:14 PM
rskrause's Avatar
Moderator
I am not a big Eagle fan, but the rod bolts are fine unless you are building an 8,000rpm motor.
Rich
Old Mar 26, 2009 | 04:18 PM
94sc383's Avatar
Rich
is it just the rpm limit or is it a hp/trq limit?
Old Mar 26, 2009 | 05:20 PM
rskrause's Avatar
Moderator
It has nothing to do directly with hp/torque. The stress on the bolts is primarily when the piston is slowing down approaching TDC (when it's in tension). The ARP 3/8" 8740 bolts could be a problem with very high rpm, especially with a heavy piston. But absolutely not in a typical LT1. After all, the PCM can only control the engine till 7,000. What are you building?
Rich
Old Mar 26, 2009 | 05:24 PM
94sc383's Avatar
no where near 7000rpms. more like 6200 rpms. i just read in a thread that the bolts are junk.
Old Mar 26, 2009 | 05:29 PM
rskrause's Avatar
Moderator
You will be fine.
Old Mar 26, 2009 | 05:51 PM
94sc383's Avatar
thats what i wanted to hear. is this still true with forced induction(turbo) say 10lbs on the street, 21lbs at the track?
Old Mar 26, 2009 | 06:11 PM
rskrause's Avatar
Moderator
Yep, a blower decreases rod bolt stress when the motor is under boost. And there will be no need to spin it to the moon.
Rich
Old Mar 29, 2009 | 11:46 PM
Someone do the math on it, please! On how much less stress a certain amount of boost takes off the rod bolts.
Old Mar 30, 2009 | 02:52 PM
rskrause's Avatar
Moderator
A piston with a diameter of 4.030" has ~12.75sq.in of surface area. With 12 psi of boost the force on the piston crown is ~153lbs.
Rich
Old Mar 30, 2009 | 03:38 PM
97 6SPEED Z's Avatar
Thumbs up
Rich
And to continue for Rich ...... a 3/8" diameter rod bolt has a cross sectional area of .1104 square inches ... divided into the 153 lb force reduction due to the 12 psi boost over the piston as it approaches TDC.... yields a total stress reduction of 1,385.9 psi per rod .... which .... spread over two(2) rods bolts .... gives a 693 psi tensile stress reduction ... per rod bolt.
Old Mar 30, 2009 | 07:50 PM
What about on the exhaust stroke, which is what REALLY stresses a rod bolt anyway?! Looks like zero benefit to me.
Old Mar 31, 2009 | 04:44 PM
blue 79 Z/28's Avatar
3/8 rod bolts are pretty pinner, run a rod with a 7/16 cap screw for ultimate strength.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
