Lights and Wipers, simple questions, please contribute your thoughts
Old Mar 21, 2003 | 08:51 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
ok, apparantly the two yellow strips (parking lights) have two bulbs each in them.... one of mine is out . it is the driver side one farthest to the rear... what part #is that if you know? about how much? (i don't wanna pay 30$ for a freakin bulb) and what do i need to do to put it in, and is it difficult (ie:removing the whole bumper)?
also,
my wipers, when the car is not going above 20mph (with thte wind blowing up on them), on the way down, are hitting HARD, kinda like they don't stop going down until they hit something... then, when i turn them off they don't drop down that extra inch like they used to in the off position... the bang is extremely annoying and pretty violent when the wipers are on the two highest settings (enough to almost chip the plastic wiper arms)... anyone know whats wrong? or any way i can fix it?
Old Mar 21, 2003 | 08:56 PM
eyeoutthere's Avatar
The bulbs are standard. Just go to the parts store and look in the book they have, or ask an associate. They are just a couple bucks.
As for the wipers, it sounds like there is something broken. I don’t know how the system works so I can’t help you on that one.
Old Mar 21, 2003 | 09:17 PM
frmula1's Avatar
thanks, ok so now i need to know about the wipers and difficulty/what i have to do to change the bulb
Old Mar 21, 2003 | 09:26 PM
The wipers could be a worn out linkage or maybe the wipers need to be reset on the drive gear if they are not sweeping all the way to the top. Could even be a motor problem.
To replace the side marker, you will have to remove the splash panel that is under the front corner of the side you are working on.
Old Mar 21, 2003 | 09:32 PM
frmula1's Avatar
it seems like they are making a full sweep... about 2-3 inches away from the very edge of the driver side windshield... and they don't seem to lack in power at all in fact its like they have too much power cause when they are on high they go spaztic
Old Mar 21, 2003 | 10:22 PM
hey01's Avatar
the bulbs arn't that hard
don't remove everything just unbolt enough where you can bend the plastic and stick your arm up in there and feel for it
kinda painful on your arm but it makes a bulb change only 10 mins without taking your whole car apart
Red Hawk 94
Mar 18, 2019 04:03 PM
Jlo
Feb 3, 2015 09:41 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
