Lighting Problem ...
Old Aug 4, 2003 | 11:46 PM
HardcoreRM125's Avatar
Finally got the car like 99% together from when i bought it totalled with a jumbled up mess of a wiring harness ... Most of the stuff works now, for those of you who read my last thread , i got the Noid lights goin now on all injectors every time , so now i just gota clean them and itll start right up. Was a bad Relay ( The Air Pump one , somehow has something to do with the injectors too lol )
Anyways , my lights area taking a big **** ... I can get the following to come on ...
All Running lights
Emergency Blinkers
Turn Signals
Passanger Side Headlight
and Passanger Foglight
However , no passanger hi-beam, no driver side head light, hi beam, or fog light...
While messing with the electircal for the fuel injectors, i checked real quick on the hi beams , and neither are getting the 12 Volts ... Any suggestions as too where to start first so i dont gotta go around probing and checkin a hundred wires tommorow lol ? Didnt check the lights since i changed the Air Pump Relay but i wouldnt think they are related, then again , i also wouldnt have thoguht the Air Pump relay had **** to do with the Injectors ground pulses either so ...
Sergio
Jan 27, 2016 04:27 PM
redleader
Jan 22, 2015 10:11 PM
97z28k&N
Jan 9, 2015 04:58 AM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
