Lifters Question
Old May 1, 2009 | 08:43 AM
meissen's Avatar
Lifters Question
Hey guys,
My car spun two bearings and had metal shavings all over the engine. I want to replace the lifters to make sure I don't have to worry about them. If I go with LS7 lifters or Comp Cams lifters do I have to worry about pushrod length or would I still be safe to stick with the stock pushrod size? I remember reading a post awhile ago that in most cases a heads/cam/intake car isn't going to need different length pushrods than stock but I wanted to check and make sure.
CC503, 1.6 Pro Mag roller rockers, 918 beehives.
Old May 1, 2009 | 12:30 PM
95Blackhawk's Avatar
Just buy a pushrod length checker along with those LS7 lifters. I did all kinds of crazy stuff to my block, heads and still came up with 7.200".
Best to be safe.
Old May 1, 2009 | 11:12 PM
WhiteThunderZ28's Avatar
Originally Posted by meissenation
Hey guys,
And your car sounded good to!
I'm doing the same setup to btw.
Old May 2, 2009 | 08:22 AM
You can save all money by disassembling your lifters and cleaning them.
Old May 2, 2009 | 08:48 AM
MichiganSkip's Avatar
yes you can. Just watch out for those pesky spring clips that go flying.
Old May 2, 2009 | 09:12 AM
meissen's Avatar
Do you think it'd be more beneficial to stick with the stock lifters and clean them than buying new? I was told the engine had 60k on the clock when I bought it but I have no way of knowing for sure how many miles was on this engine.
Old May 3, 2009 | 08:30 AM
I have friends that run stock eliminator LT1's that use used lifters all the time. I wouldn't be afraid to use them if they are in good shape. It will benefit you in that you will save whatever the price is that a new set will cost you. On the other hand, if you decide to use new ones, can I have your old ones??? I'll pay shipping, of course
Old May 3, 2009 | 09:21 AM
meissen's Avatar
Haha well if I can reuse these I'm definitely up for it.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jj_burchiel
Mar 5, 2015 07:05 AM
donot_4get
Sep 14, 2002 08:03 AM
