lifters bleeding off
Old Jan 21, 2006 | 11:35 PM
  #16
1racerdude's Avatar
Re: lifters bleeding off
The original ticking was the valves hitting the pistons? Did it break a spring or the valve hit the piston breaking it?
Old Jan 22, 2006 | 09:33 PM
  #17
TransAmGT94's Avatar
the valve hit the piston and when it did it broke off. It was still attached to the spring.
Old Jan 22, 2006 | 09:43 PM
  #18
1racerdude's Avatar
Old Jan 24, 2006 | 08:35 PM
  #19
new info. the machine shop is telling me that i have damaged 4 pistons and 1 rod. they also said that i would have to go from the 40 over to 60 over on the block so the only things i have still good are the crank 7 rods cam and heads with some work about 700 to give u a dollar amount. I have a virgin block and heads still assembled. Im looking for the best method of going about redoing it. do i sleeve the cyl and go 60 over, use the virgin and go 20 over or scrap them both get a assembled short block. just trying to get some place to start cause it looks like im starting over just about.
thanks in advance
chris
Old Jan 24, 2006 | 08:37 PM
  #20
Dave89IROC's Avatar
go virgin, allways better............
Old Jan 24, 2006 | 08:39 PM
  #21
thats kinda what i was thinking and it will be about the same price all ill have to pay extra for is reclearanceing it for the crank
Old Jan 24, 2006 | 08:46 PM
  #22
1racerdude's Avatar
thanks in advance
chris
.060 is going to be hard to do in a stock block. It makes the wall's to thin.
If ya have 4 bolts already installed then I would sleeve the cyls that need it and get some pistons.
This time check THE P/V CLEARANCE or get the right valve springs.
Old Jan 24, 2006 | 08:55 PM
  #23
they are doing the assembly this time the cracked one is a stock 4 bolt the virgin is a two bolt
Old Jan 24, 2006 | 09:22 PM
  #24
1racerdude's Avatar
I would fix the cyl's in the 4 bolt. There is nothing wrong with properly installed sleeves.
Ya got to weigh the cost of doing the new block,converting to 4 bolt, and all the other machine work to make it like the damaged 4 bolt and what the cost is to fix the 4 bolt.
Formula Steve
Sep 19, 2023 08:31 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
1bad427ls1
Sep 23, 2015 01:12 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
