lifter tick/low rpm stumble
Old Jun 27, 2012 | 07:49 PM
mrcallison's Avatar
Angry lifter tick/low rpm stumble
I am currently having issues with what I think is a ticking lifter, I plan on breaking it down and replacing all 16 but in the mean time i was wondering if anyone could suggest an oil additive that might help quiet the tick. Also I am experiencing a low rpm stumble any suggestions
Old Jun 27, 2012 | 11:11 PM
Re: lifter tick/low rpm stumble
Are you sure it's not a header gasket leaking/ticking? An exhaust leak before the O2 sensor will cause the engine to run rich.
Old Jun 28, 2012 | 10:19 AM
mrcallison's Avatar
I have checked the headers i have no leaks im almost positive its a lifter had several certified technician say the same. How ever I do not have the o2 sensors hooked up I guess that could run it rich
Old Jun 28, 2012 | 11:52 AM
mrmint69's Avatar
Why are they unhooked? Not a good idea!!
Old Jun 28, 2012 | 12:24 PM
Which O2 sensors are disconnected? Pre-cat, after-cat, or all? In the other thread you asked about using simms or tuning them out, which would apply to the after-cat sensors.
Old Jun 29, 2012 | 10:50 AM
mrcallison's Avatar
I have ordered some 02 sensors sims and i went to hook up the front O2 sensors in the mean time and realized the fronts are 4 pin flat so gotta pick another pair of sensors i guess? I'm having trouble locating the drivers side rear sensor plug any suggestions?
Old Jun 29, 2012 | 10:53 AM
mrcallison's Avatar
to answer your question all are disconnected i figured it would throw codes no matter, I have plug extensions and plan on hooking the front up this afternoon once i pick up some new sensors
jbert55
Oct 31, 2015 03:52 PM
97SSdude
Aug 21, 2015 09:36 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
