Lifter tick? (Clip inside)
Old Jun 7, 2013 | 02:20 PM
94Form's Avatar
Trying to figure out what this ticking is, thinking its a lifter. Lifters are Comp R bad design ones. Listening with a stethoscope it seems to be coming from cylinder 2 intake. Did take the intake off to visually inspect the lifters and they all look like new. Oh and oil pressure is normal.
https://www.youtube.com/watch?v=p93SyI5VYJQ
Old Jun 7, 2013 | 04:19 PM
John95z28's Avatar
Re: Lifter tick? (Clip inside)
I can usually tell a lifter tick with %100 acuracy, but in this clip I could not hear one. Sounds exhaust related, or maybe ignition. Are you noticing the sound more on cold start or after warmed up?
Old Jun 7, 2013 | 04:49 PM
94Form's Avatar
It sounds the same to me on cold start and after warmed up.
Right before I started having this problem I took the passenger side header off to shave a little off the transmission flange it was hitting. Put the header back on and this problem came up. Thought it was an exhaust leak so I took the header off again and put a new gasket on. Problem still there. Also in addition to the ticking, my brakes feel like there is air in the lines now, and runs rough under load. I did nothing with any vacuum lines. This all happened at once.
Old Jun 7, 2013 | 05:05 PM
John95z28's Avatar
Ok it is unusual to have the tick both when cold and warm. A bleeding lifter leaks out causing it to tick cold. A flat lifter will tick after warm up when the oil thins out a bit.
Good that you shaved the trans flange to avoid false knock and you know the gasket is good. hmm, did you remove the intake before or after this?
I thought it sounded like a leaky intake manifold which could give you those symptoms...And the EGR tube going into the intake is connected?
Old Jun 7, 2013 | 05:13 PM
94Form's Avatar
This video was after I took the intake off. It sounded exactly like this before I took it off though. The EGR has been deleted and blocked off... Would it be worth it to redo the block off plate? Or would that not be a possible problem here?
Old Jun 7, 2013 | 05:44 PM
John95z28's Avatar
Oh its deleted, I was thinking possible intake/exhaust leak but not if it is blocked. Unless you are mistaking a tick for a ping then un-deleting the EGR could help ofcourse. Maybe take another video with camera closer and at various rev points might help. You've got a good description of the problem so far.
Old Jun 7, 2013 | 06:11 PM
94Form's Avatar
https://www.youtube.com/watch?v=bDd-d90trbQ
I did take my AC lines off and haven't replaced the compressor with a pulley yet... I doubt that is the problem but just to be sure I'm throwing that out there...
Old Jun 7, 2013 | 06:21 PM
jloshotz's Avatar
The compressor won't make noise like that, unless the clutch is pulled in, as in A/C or defrost on
Old Jun 7, 2013 | 10:26 PM
Chet1185's Avatar
That's not the injectors is it?
Posted from Camaroz28.com App for Android
Old Jun 7, 2013 | 10:51 PM
94Form's Avatar
Would I just listen with the stethoscope? Or is there a more precise way to test
Old Jun 8, 2013 | 12:21 AM
Chet1185's Avatar
Not sure. I'm pretty sure I can hear mine just with my ears.
Old Jun 8, 2013 | 03:25 AM
John95z28's Avatar
To test the injectors you can remove one at a time while running.
To test the lifters with steth, probe the rocker studs(valve covers off).
9t4lt4z28
Oct 2, 2015 10:28 AM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
