Lifter suggestion
Old Dec 23, 2005 | 03:09 PM
walt355's Avatar
Lifter suggestion
Heres the deal. Im going to a larger cam this winter and decided I need new lifters beings how the one Im running now are 90K mile stock lifters.
Heres what I found so far.
Lunati 360
Crane 260
GM stock perplacements 530
Morals 480<,SO Im told
And the Comp Rs are junk.
Any more suggestions. Right now Im looking at the Cranes or Lunatis.
thanks
Walt
Old Dec 23, 2005 | 05:34 PM
1racerdude's Avatar
Re: Lifter suggestion
Your stock ones will be fine if they are in good shape. Check the wheel(bearing) for tight spots and looseness. Check the bottom of the lifters for cracks and the bearing pin on both sides to make sure they are tight.
There is no guarantee on new ones out of the box and yours have been tested,
Old Dec 23, 2005 | 06:07 PM
Compstall's Avatar
I put my cam in at 90,000 miles also and did the same thing you are planning to do. I spent $230 for GM replacements. If I didn't already have the new ones, I would have easily used the originals because darn if they didn't look just as good as the new ones.
Old Dec 24, 2005 | 09:09 AM
walt355's Avatar
Thanks fellas, I uess when I oull them out if they look good Ill shove em back in. Thanks again
Quickss96
Jan 29, 2016 05:56 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
97SSdude
Aug 21, 2015 09:36 AM
4586
Jul 31, 2015 06:03 PM
