Lifter Install Question
Im at the final stages of the cam swap now and I have another question. Im about to put the intake back on but first I have to get the lifters in. Now a buddy of mine told me that I need to put the lifters in the holes that they came out of. Is this true because if so I may be screwed. Is there a way of identifying which lifter goes in which hole. Also the roller part faces the cam right because for some reason I cant get it to go in that way. Thanks for all your help guys.
You have a roller cam and roller lifters, it doesn't matter. Make sure you soak them in oil for a while before reinstalling them. I even put about 2 qts of oil in the valley right before I put the intake on as well.
Now, they do say to lube the bores and lifter thoroughly, but not to soak them for a while.
Soaking them accomplishes the same thing as lubeing them throughly. You want to get the air out and the oil in. It sort of reminds me of the reason you put oil in a oil filter before you install it on the block. Less time passes for oil pressure to build and for oil to do its job.
oldschool
Feb 9, 2016 09:21 PM
Chrisdude
Jul 24, 2002 02:25 PM
