Lifter adjustment/New Cam
Old Jul 5, 2010 | 06:04 PM
camz28ryan's Avatar
1996 LTI
Installed LT4 Performance Hot cam. I had the intake off while adjusting the lifters and tried to follow the instructions from the chilton book and the lifters that we were supposed to be adjusting was on top of the lobe not the bottom. Yes we had it TDC and everything was lined up and set up the way it was supposed to. My question is does the Hot make the lifters ride on the lobe differently than a stock cam in a way that u can't adjust them in the order u are supposed too? Example, we were at TDC and on the first pass we were supposed to adjust exhaust valves 1,3,4,8. The number 4 exhaust was on top of the lobe so we couldn't adjust at that time.
We ended up adjusting all of them that was on the bottom and turning the crank until we could adjust the rest. The car is running and back together but how do I now adjust again without taking off the intake. I know u can do it while the car is running but i was just concerned about the cam not lobing up the same.
Old Jul 5, 2010 | 06:43 PM
There is nothing different about the cam lobes. You apparently did not have it at the right cylinder TDC. You probably had 1 and 6 reversed.
Old Jul 5, 2010 | 06:58 PM
camz28ryan's Avatar
I found TDC by taking #1 plug out, turning crank untill it blew my finger off. The pin on the cam was at 9 and the arrow on the harmonic was at 12. Am i missing something?
Old Jul 5, 2010 | 08:13 PM
That would be #1 TDC. I can't tell you why you could not adjust the valves as indicated (unless there is some trouble with cylinder identification???). You should have been able to. Other folks seem to do it.
Try another method. There are several listed on my Tech Page.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Jul 6, 2010 | 07:37 AM
bw_hunter's Avatar
Rotate the engine 1 turn after tdc on the compression stroke (which you described) and everything will be as you were expecting....adjust with any of the methods descibed on Shoebox's site.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 08:12 PM
