Let's say you were going to swap in a first gen block??
Old Jan 7, 2004 | 07:37 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
What heads would you run on it(11*/18*). How about Brodix? Lets look at most bang for the buck here, and your goals are 600rwhp, and mid 500's on torque or more.
The car might see a couple of hundred miles a month on the street and alot of drag strip time.
What Solid Roller might you run? What compression? Still maintaining fuel injection here so Fast will take care of the computer system. Or maybe a carb setup would be a better choise. What would you do. Though I'm going to run injection.
The reason I ask is, if I don't do a custom Turbo Kit next month, I'm going to sell everything, which has about 1,500 miles on it, and do the swap.
I should still be able to run my 6 speed. I think the bellhousing is pretty much standard, but not sure??? Ok let hear it.
Neal
Old Jan 7, 2004 | 09:20 PM
97WS6SCharged's Avatar
If you're expecting to see 600 rwhp, you're better off buying an aftermarket block like a motown or dart or something. And, if it's NA, I doubt you will want to drive it on the street.
Old Jan 8, 2004 | 10:07 AM
PNYKILR's Avatar
That's what I was talking about???? First gen block.
Old Jan 8, 2004 | 10:29 AM
93Z286Speed's Avatar
My dad had Brodix track 2 heads (un ported) on his 355 Small block in a 73 Nova.. Ran 9.90s on 118 octane and 1 4barrel carb. Soo having said that, i vote bordix track 2 heads.. This thing wasnt a street car though.. had a 6.32 rear gear being drivin by a power glide
Old Jan 8, 2004 | 07:15 PM
MPM IV's Avatar
I've also considered this swap. I'd like to see some more opinions.
Old Jan 8, 2004 | 07:23 PM
TheV6Bird's Avatar
Question
Will the Gen I SBC distributor fit in a cramped 4th gen engine bay?
Old Jan 8, 2004 | 09:08 PM
Yeah, a distributor will fit back there, but good luck if you have to remove it.
jayvar
Feb 2, 2015 10:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
routesixtysixer
Jun 23, 2002 02:29 PM
