lets play the HP game
Old Jan 20, 2014 | 11:26 PM
SuperSportSS's Avatar
Heres a complete list of my mods tell me what uou guys think ill run after a mail order tune and after a dyno tune. Trying to decide what would get me more power to the ground
Engine:
Ported heads (gasket matched and casting flash smoothed on bowls)
Ported intake
BBK 52MM TB
24# bosch injectors (have 36# GTP injectors going in for the dyno)
fans wired to 12v toggle(s)
Scorpion 1.6RRS
SLP air lid
K&N filter
Deleted air
Deleted egr
Deleted ac
BBK headers
ORY pipe
custom grind comp cam224/236 540/554 114LSA WITH 1.6RRs
New timing set
LS7 lifters
650 lift springs
Hardend pushrods
Scat crank
Manley rods
Flat top pistons
Bored 0.040 over
Throttle body bypass
All new gaskets
Transmission:
Stg 2 rebuild
2200 vigilanti stall
Drilled corvette servo
Trans go stg 2 shift kit
Sol pack
Kevlar band
Redline clutches
Hardend steels
Beast sunshell
Drilled seperator plate.
Rear end:
1999 formula 10bolt
New carrier
33 spline axles
4:10 gears
New rotors
New brakes
Suspension:
Rear LCA relocation brackets
36mm sway bar
Poly sway bar links (rear)
Ws6 rear springs
Decarbon shocks
energy tourqe arm mount
energy trans mount
Umi front sway bar
Umi strut tower brace
Poly sway links (front)
Who ever is closest to my hp will get a free prize!
Old Jan 20, 2014 | 11:27 PM
Re: lets play the HP game
But on a side note now you all know why i have so little in my sig lol way too much to list applies here
Old Jan 21, 2014 | 07:54 AM
Flywheel of rear wheel HP?
You need to reduce the list to things that actually affect HP. Listing the interior and exterior mods just confuses things.
What do the ported heads flow? Who ported them? Who tuned it.... mail order or dyno? What are "faves"? What is the static compression ratio? Shorties?
You aren't going to reach your 500HP goal with 24#/HR injectors.
Old Jan 21, 2014 | 12:30 PM
To make it alittle more difficult we will make it to the flywheel. I posted this late lastnight and some things were typos, ive deleted the things i thought werent needed but i did leave the suspension section.
And i will have 24# hr injectors untill my car physically gets onto the dyno because im going to have my dyno tuner try and crank every bit of power out of my z28.
Im really suprised no one else has chimed in
Old Jan 21, 2014 | 01:44 PM
Why is it harder to estimate at the flywheel? That eliminates concerns about the trans, converter lockup, rear axle ratio, etc. To me that's a lot easier. An auto trans also corrupts the peak torque, with a huge surge/spike when the converter is multiplying torque. The guys that built my engine won't even show torque values for chassis dyno results through an auto trans.
Look at the real list of things that determine power:
Engine:
-Ported heads (gasket matched and casting flash smoothed on bowls)
-Ported intake
-BBK 52MM TB
-24# bosch injectors (have 36# GTP injectors going in for the dyno)
-Scorpion 1.6RRS
-SLP air lid
-K&N filter
-BBK headers
-ORY pipe
-custom grind comp cam224/236 540/554 114LSA WITH 1.6RRs
-Flat top pistons
-Bored 0.040 over
-Throttle body bypass
Old Jan 21, 2014 | 01:49 PM
Everything else is posted aswell because on when i dyno the car it will help with the rear wheel estimate aswell. If its easier for you with flywheel hp whats your guess?
Old Jan 21, 2014 | 06:24 PM
Mr99SS's Avatar
I don't do hp #'s I say mid 11 to low 11's motor
Old Jan 21, 2014 | 08:46 PM
Alright mr99ss thats fair. When i run it at the track next season ill personaly let you know what my best time is
Old Jan 21, 2014 | 09:11 PM
bw_hunter's Avatar
430 at the flywheel....
Old Jan 21, 2014 | 10:00 PM
Matts97camaro's Avatar
I am going to say 405 hp at the flywheel. Low to mid 12's with street tires.
Old Jan 21, 2014 | 10:11 PM
Mr99SS's Avatar
I drove a buddies c5 230k stock car 13.0's real street tires 13.07 best @ Darlington dragway sc
Old Jan 21, 2014 | 11:27 PM
Also guys ill be running a set of 315 drag radials on the track and the dyno,
Old Jan 22, 2014 | 09:03 AM
Without knowing any details of the heads, compression ratio, etc. it's impossible to even guess. But I will say that the two flywheel guesses above are in the ball park. No way it's going to run low 11's unless you get the weight down to about 3,000# w/ driver.
Old Jan 22, 2014 | 01:44 PM
I cant remember what my heads were flowing but i do know i have 11:5:1 comp. Ill see if i can find my flow charts on the heads
Old Jan 22, 2014 | 02:02 PM
My heads are flowing at
Intake .600/238
Exhaust .600/176
Which isnt bad for a home port job and not touching the bowls at all!
