length of OTVC wires
Old Feb 28, 2004 | 09:14 AM
30thannZ28's Avatar
This is a really long shot here, but does anybody happen to know the exact length of all 8 wires that need to be cut from the universal Taylor wire kit if I have the made for you over the valve cover kit and jet hot LT's??
Old Feb 28, 2004 | 09:55 AM
orrink's Avatar
No just hook them up to plug and route properly then cut before insertion into opti. I paid to have it done but could only route 6/8 due to PCV. Watch the wire near the dip stick as it will arc if too close.
Old Feb 28, 2004 | 10:58 AM
scoobysnax83's Avatar
No it won't... What do you think your valve covers are, or half the "metal" things it comes into contact with.
You had a brain fart
Old Feb 28, 2004 | 11:20 AM
Alvin@pcmforless.com's Avatar
yeah it will,
that dipstick gets hot when its next to headers.
You should keep it away from as much metal as possible.. espeically hot or sharp corners
Old Feb 28, 2004 | 11:29 AM
yea it probably does get hot. But no hotter than your wires would be get being next to the same headers
Old Feb 28, 2004 | 05:01 PM
orrink's Avatar
Angry
Talk about brain fart. I watched my new wire arcing to the dip stick.
Old Feb 28, 2004 | 05:06 PM
If your wires are arching in anyway shape or form. Something is wrong. You should be able to grab your wires with your hand and not get shocked. (Don't try that, cause if they're bad it hurts like a ****) But think about it. Your wires touch about 4 other metal objects and yet you are focusing on the dipstick.
Old Feb 28, 2004 | 05:51 PM
orrink's Avatar
The head of the plug wire where it connects to the plug was hitting the dip stick. I took out the slack and its running GREAT on all 8 now.
Old Feb 28, 2004 | 09:15 PM
Alright, your situation may be different. But I will stress this one more time. If your plug wires are arching (in any situation) then there is a problem. If it is arching close to the head, you probably have cracked ceramic on your plug. This usually is the result from them being dropped. Weither you did it, or the parts store.
Old Feb 29, 2004 | 01:06 AM
orrink's Avatar
OK, I'll check it out. It's running great but anything's possible. I saw the spark jumping from the 90 degree plug connector to the dip stick.
Old Feb 29, 2004 | 07:34 AM
30thannZ28's Avatar
I don't believe it, my thread was hijacked!
just kidding. It was a stupid question in the first place. I just figured lazy ole me just might find someone who measured their wires. I guess everyone routes them differently anyway. I've seen some route them DIRECTLY behind the alternator and some go under the alt.
oh well.
GLAD YOU GOT SOME INFO OUT OF IT ORRINKER!!
Old Feb 29, 2004 | 11:25 AM
orrink's Avatar
It's true and I did. Thank you. Good luck but you are correct, each wire must be custom made as you do the job.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
chuyz28
Feb 19, 2015 12:50 AM
GigaMp3z
Feb 20, 2003 02:57 PM
$hawn
Aug 28, 2002 09:09 AM
