Left Bank Rich?
Old Feb 26, 2008 | 08:32 AM
DAVE00's Avatar
Left Bank Rich?
Guys/Gals,
Have a slight problem, I am running very rich on the left bank pegged around 108 while the right bank is perfect around 126-128. Seems to only happen at idle and when the rpms go up the LTerm counts even out on both sides. Anyone know what could cause this? I have tripple checked and no exhaust leaks, brand new O2's and I have swapped the O2's as well from side to side and the problem stays on the left bank. Could this be a sticking injector maybe? Let me know your ideas and here are some specs on the motor:
LT-1 - 383
CC305 Cam
AFR 195 heads
SVO 30# inj
Old Feb 26, 2008 | 08:51 AM
MEAN LT1's Avatar
That would be a good idea to swap injectors and see if it follows. Also check your plugs and wires(never know).
Old Feb 26, 2008 | 09:11 AM
The BLM drops to 108 when the PCM believes that bank is running rich. But the O2 sensor can only "see" oxygen, not fuel, so a leaking injector may not cause the O2 sensor to indicate a rich mixture. 108 is as low as it can go, so it might be worth looking at the short terms for the left bank as well, to see if they are spending more time below 128 than above.
Exhaust leaks and misfires cause a "false" lean and drive the BLM's up, not down.
What throttle body are you running? Some seem to cause problems with "spilt" BLM's at idle. The cam doesn't look big enough to be causing reversion problems.
Old Feb 26, 2008 | 12:27 PM
DAVE00's Avatar
The BBK 58mm tb. Plugs and wires all look good, seems really odd. Any more advise?
Old Feb 26, 2008 | 12:29 PM
DAVE00's Avatar
Just to confirm, dumb question, but the left bank is the Driver Side of the car correct?
Nayr
Mar 3, 2023 08:34 PM
damnyankee36
Sep 9, 2015 07:06 PM
MDZ28
Sep 7, 2015 09:16 PM
WPHIG2
Aug 27, 2015 06:37 AM
zajones
Jul 30, 2015 02:18 PM
