Lean hesitation on '95 LT1
Old Sep 26, 2005 | 10:40 PM
engineermike's Avatar
I've been trying to fix this for some time now. When I tip in the throttle abruptly, the engine consistently stumbles, even backfires. The wideband shows a spike up to ~18/1 A/F ratio instantaneously. I have 84 lb/hr low impedence injectors and the Acceleronics impedence converter. The car runs fine otherwise. Any ideas?
Mike
Old Sep 27, 2005 | 12:12 AM
1racerdude's Avatar
Re: Lean hesitation on '95 LT1
Mike
Your tip in fuel is lean,like the acceleration pump on a carb.
Old Sep 27, 2005 | 05:52 AM
Okay. . . can you tell me how to fix said problem???
Old Sep 27, 2005 | 12:34 PM
1racerdude's Avatar
Not exactly other than let Ion or Bryan have it for a tune.
Old Sep 27, 2005 | 06:35 PM
Silver's Avatar
geez. post in the computer/diagnostics section. hopefully someone will tell you. never noticed this in lt1 edit though.
Old Sep 27, 2005 | 07:14 PM
I guess I'll double-post. . . I'd rather not let someone else do the tuning on my 850+ fwhp turbo motor.
Mike
Old Sep 27, 2005 | 07:26 PM
turbo_Z's Avatar
Oh I like this problem.
Here is how i fixed it. With tunercat I went in and opened up the %TPS to enable PE mode table. Then in the RPM range I was experiencing this problem I just lowered the TPS to like 25-30% instead of 60% which is A LOT of throttle. So now when you want to get on it PE kicks in and compensates earlier which should prevent that lean stumble.
Old Sep 27, 2005 | 07:29 PM
1racerdude's Avatar
Mike
I know what ya mean.
I let one guy fool with my shop car WITH me there,because he has the equipment to reflash the computer. I know what I want it to do and tell him,he pushes the buttons. He is also one of the best in the country,if not the best on Fords and has a 8 second ride. I built his last one and he flipped it and he bought this one built.
I can ask him if ya want.
Old Sep 27, 2005 | 08:57 PM
So, how are you not cruising in PE mode, then???
Old Sep 27, 2005 | 09:06 PM
turbo_Z's Avatar
I just checked and mine are set at 42% from 1600-2400 rpm. With those settings I dont run in PE mode while cruising.
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
