Leaking rear-end on exhaust
Old Oct 8, 2003 | 06:42 PM
ibanez6rg's Avatar
So my rear is leaking a tid bit and a little tid bit of that is getting on my exhaust. Should there be anything to worry about with that? Does that type catch fire/could it catch fire?
Old Oct 8, 2003 | 06:46 PM
Kataklysm's Avatar
No, its just gear oil and it will burn off, at worst it will have a smell
Old Oct 8, 2003 | 06:53 PM
ibanez6rg's Avatar
Maybe that's what I've been smelling
Old Oct 8, 2003 | 07:04 PM
AG's93Z's Avatar
I am having the same problem, the seal is leaking and letting gear oil leak over my I-pipe to the muffler!
Old Oct 8, 2003 | 07:15 PM
RamAir95TA's Avatar
I rarely see another f-body that doesn't leak fluid out of the pinion seal. A small amount is normal, but an excessive dripping is not. Pinion seal replacement would be required.
Old Oct 8, 2003 | 07:20 PM
Kataklysm's Avatar
The pinion is easy to do anyways if its bad, go buy a chiltons manual if you don't have one already, they are great.
Old Oct 8, 2003 | 07:31 PM
gb95zconv's Avatar
Mine leaks a bit too...I replaced it once and it started leaking again a few weeks later. I just keep an eye on the fluid level now.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
