Leaking Oil!!
Old Jun 27, 2004 | 03:29 PM
Downshiftndrift's Avatar
Leaking Oil!!
I have a 95 Z28 with the Lt1 with 150,000 miles on it and NO rebuild and i bought it for a thousand bucks...I was told it was the back seals that were the problem and it just spits oil right out of the motor...making the car non-drivable. How much would this cost in parts and do myself? I'm new to the chevy crowd and not too sure where to look. Either a rebuild or new motor is coming soon but I need the car drivable before then. Thanks for your help guys.
Old Jun 27, 2004 | 03:36 PM
Spinner's Avatar
Rear main seal is cheap to fix, but lots and lots of labor. Easiest way is to drop the tranny.
Intake is also cheap. Takes ~2 hours
Old Jun 27, 2004 | 03:42 PM
Dave89IROC's Avatar
First thing to do would be to find out exactly where the oil is leaking
there are several possiblityies
reach back past the intake and see if you can feel oil behind the intake, on the top of the trans if your arm is small enough
if that is dry, fill the oil up to the full mark, then start the car, if it is coming out fasst, it should be easy to find, if slow, turn it off, clean it all real good(engine degreaser, ect.), then start it and check again, if it is still hard to tell, get a U/V leak detection kit from ma local parts store, follow the instuctions
of the possible leaks, rear main is probably the hardest to fix
Old Jun 27, 2004 | 03:46 PM
Yea I already had my boys that are mechanics look at it...its definately the rear seal and they said i'd have to take the motor out and do it that way...UGH THIS IS A PAIN...but hey u pay a thousand bucks for a car and you have to expect lots of labor uno...thanks alot guys
Old Jun 27, 2004 | 03:55 PM
Spinner's Avatar
Dont pull the motor, that's silly. Drop the transmission and get it with the motor in the car.
Old Jun 27, 2004 | 03:59 PM
aight ill give that a try good idea bro...I just found the seal on Racenet.net for $19.95. Didn't know it would be that cheap. Thanks for your help
Old Jun 27, 2004 | 04:13 PM
Spinner's Avatar
Could probably get it at a local parts store for $15. I paid $12 for my felpro
Old Jun 27, 2004 | 04:23 PM
gb95zconv's Avatar
Get the seal locally...I got mine at Autozone for $17.
Like Spinner said, just pull the tranny to get to the seal.
Old Jun 27, 2004 | 08:10 PM
jbird's Avatar
I agree w/the above, try to get your seal locally, and when you do it, pull the tranny, it'll be much easier, though still a pain.
Old Jun 27, 2004 | 09:55 PM
944v8inDFW's Avatar
Once upon a time...
Withing the last 10 years i bought a Chevy S-10 for $800 "because the rear main and oil pan gasket leaked" I put it on a lift and with a couple other eyes confirmed the intake was not leaking and it HAD TO BE the the rear main. I figured for $800 I could work on it quite a bit. So i drove it to the car was spent 45 minutes getting as much oil as i could off the bottom of the truck. Then drove home right to the garage on ramps. About an hour later I decieded it may be cool enough to start pulling the tranny to change the rear main. As i was poking around figuring out how the linkage came off a fresh drop of oil land on my forehead from the oil sending unit. I replaced the sending unit and valve cover gaskets for GP for under $20 and drove the truck another 5 years with no leaks. So you might check the simple stuff first. On the lt1 the oil sender is at the back of the motor up high and i would think if it was puking oil it may look like a rear main leak. Just my 2 pennies.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
surreybrad
Apr 22, 2015 06:40 AM
artic94
Jan 17, 2015 11:19 AM
Jessie4tin
Jan 7, 2015 08:53 AM
