Leak from the Thermo Housing
Old Feb 6, 2005 | 12:54 AM
ponyackn's Avatar
I just replaced the waterpump with a remanufactured wp. The reman wp appears to have a rough surface around the edge of the opening where the thermostat housing sits.
It is leaking slowly when the car runs.
How should I stop this? I have black rtv, should I use that? How would I go about smoothing out the surface if I can't use rtv?
Old Feb 6, 2005 | 09:45 AM
indieaz's Avatar
Re: Leak from the Thermo Housing
RTV would be fine. There is a rubber gasket in there on the thermostate - it's possible the gasket is no good. Have you tried unbolting the thermo housing to see how this looks? That is probably your problem - either that or it just needs to be tightened down in general.
Old Feb 6, 2005 | 10:23 AM
ponyackn's Avatar
Well I tightened the 2 bolts down pretty good. I didn't quite check the thermostat's rubber though. I'll check that.
But the finish quality on the surface of the reman'ed waterpump was lousy. It didn't look smooth and machined, only rough and pitted. That's why I assumed it to be the culprit of the leak.
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
