LE3 Heads just in...
Old Jun 25, 2006 | 09:53 AM
  #31
Honda Hunter's Avatar
Re: LE3 Heads just in...
Near Brownsville?
Old Jun 25, 2006 | 09:55 AM
  #32
Jlo's Avatar
Jlo
Wow, you guessed it. I live in Brownsville,TX how'd you know.
Old Jun 25, 2006 | 10:52 AM
  #33
Josh'95Z28conv's Avatar
Originally Posted by Honda Hunter
What are you looking to run?
My goals are pretty light for my setup. I want to run as deep into the 11's as I can with a 3800# car, then spray into the 10's. Im gonna spray a 200 shot at least once, and see how quick I can get kicked off the track. With a roll bar Im only going to be legal down to 10.99 in the vert though
Old Jun 25, 2006 | 11:40 AM
  #34
Jlo's Avatar
Jlo
Sweet deal. There are a few guy's here running 383's on spray, I know one for sure is using stock unported trickflows and runs low 12's high 11's and on spray he's gone to a best of 10.60's on a 150hp. I know you're running a 383 with the LE3 package. Lloyd told me this
"The 355 is the way I would go. A 383 will just restrict the RPM range since the LT1 castings feed the 355 better. A 355 car will end up being faster. Just get good pistons and rods/bolts. An aftermarket crank is nice if you have the budget. Just keep the engine from detonation on NOS and you will be fine." Although I did plan on using a new pro comp scat crank and there 4340 6" 7/16 rods with Mahle pistons.
Old Jun 25, 2006 | 11:45 AM
  #35
Jlo's Avatar
Jlo
I'd say I would have to agree with what Lloyd says about the LT1 castings.
Old Jun 25, 2006 | 11:48 AM
  #36
97SprChrgd383's Avatar
On the combustion chamber on the heads though, with it being n/a and using possibly a 200 shot, what size cc on the heads would be best for that?
Old Jun 25, 2006 | 12:54 PM
  #37
I dont mind having the rmp down a little from the 355. Hell, I dont like revving that high anyway. But the extra torque of the 383 will help greatly with my 3800# heavyweight. But I did have lloyd do a little extra work to the castings over the normal LE3 job
Old Jun 26, 2006 | 10:41 PM
  #38
Jlo's Avatar
Jlo
Sweet deal, but what was the extra work??
Old Jun 26, 2006 | 10:49 PM
  #39
Its a secret
Naw, I just had the pushrod area welded up for a little more volume in the intake runners. Hopefully it will let the stroker breath a little better.
Old Jun 26, 2006 | 10:52 PM
  #40
Jlo's Avatar
Jlo
keep me posted on the build, I'd like to see how it turns out for you.
Old Jun 26, 2006 | 11:07 PM
  #41
Dan Parker '96's Avatar
You'll be happy. I ran a '96 Vette with 3.07 rear gears, LE2 heads/cam and a 75hp shot (2800 stall) at a tick under 11.9 sec and a bit over 120mph with 127 degree track temps.
It'll improve on that with some gearing.
Old Jun 27, 2006 | 08:15 AM
  #42
Jlo's Avatar
Jlo
was that on a 350/383?? those are pretty good times.
Old Jun 27, 2006 | 09:36 AM
  #43
Wckd94Z's Avatar
great conditions
Old Jun 28, 2006 | 01:35 PM
  #44
user 647483's Avatar
355
Old Jun 28, 2006 | 04:10 PM
  #45
cleangene's Avatar
Ok, I am new at this, LE2 & LE3 heads, can you tell me the different in stock and the LE2 and LE3's
Thank Scott
