LE3 Heads just in...
Old Jun 23, 2006 | 03:10 PM
  #16
Jlo's Avatar
Jlo
Re: LE3 Heads just in...
Also, what are you 355 guy's running in the 1/4 with a simular set up??
Old Jun 23, 2006 | 03:20 PM
  #17
Javier97Z28's Avatar
Moderator
11's won't be a problem at all.
I cracked 11's on my first LE2 shakedown run on my stock shortblock.
With my 355, same LE2 heads, and LE3 cam I should be much deeper into the 11's.
Old Jun 23, 2006 | 03:27 PM
  #18
Jlo's Avatar
Jlo
Well I hope I'll be able to run 11's n/a, then I'll dethrone some LT1's here in the valley with the juice. I think the fastest one here runs a 383 LT1 with a TNT nitrous kit and hits 10.60's or so with a 200hp shot, runs low 12's on motor. Hey, Javier I've been keeping tabs on you're build it's a 355 right, tell me how it's coming along. I just might build somthing simular to you're build. Also what pistons did you use and the CC's of youre LE2's so I can order the same ones "pistons". What do you think youre camaro will hit?? any noticeable difference with the 355 than what you had before??
Old Jun 23, 2006 | 03:44 PM
  #19
Jlo's Avatar
Jlo
OH!! what intake gasket should I use with these heads?? anyone have part#'s??
Old Jun 24, 2006 | 06:57 PM
  #20
Jlo's Avatar
Jlo
Were the LE packages made for stock to 355 LT1's??
Old Jun 24, 2006 | 07:02 PM
  #21
Mike96z's Avatar
How much did it cost?
Old Jun 24, 2006 | 07:08 PM
  #22
Jlo's Avatar
Jlo
did what cost??
Old Jun 24, 2006 | 07:40 PM
  #23
97WS6NY's Avatar
FELPRO 1074 is generally the reccommended head gasket in these setups
Old Jun 24, 2006 | 07:43 PM
  #24
Jlo's Avatar
Jlo
I already have the 1074 felpro head gaskets, what I needed were the intake gaskets, I figured since the LE3's have an intake runner of 208 or so I was wondering if it needed a specific race intake gasket.
Old Jun 24, 2006 | 08:23 PM
  #25
Zigroid's Avatar
did you tell lloyd what you were doing? different cams are used for 355s and 383s.
Old Jun 24, 2006 | 11:05 PM
  #26
Jlo's Avatar
Jlo
I talked to Bret about that said it would work fine.
Old Jun 24, 2006 | 11:45 PM
  #27
Mike96z's Avatar
How much does it cost to have heads flow tested?
Old Jun 25, 2006 | 04:24 AM
  #28
Josh'95Z28conv's Avatar
In the valley? From southern texas? Ill have mine running soon
Old Jun 25, 2006 | 05:33 AM
  #29
Honda Hunter's Avatar
What are you looking to run?
Old Jun 25, 2006 | 09:47 AM
  #30
Jlo's Avatar
Jlo
Yup, South Texas. Way down South Texas about 10min away from Mexico.
