LE3 Heads just in...
Old Jun 22, 2006 | 09:44 PM
Jlo's Avatar
Jlo
Wink LE3 Heads just in...
They are 2.055/1.60 valves.
Here are the flow #'s . . . . . . .
.2 143/110
.3 198/143
.4 243/171
.5 274/184
.6 284/196
.650 287/201
Lloyd Elliott
972-617-5671
Eportworks.com
These are directly from Lloyd.
So what do you guy's think I should build??
a high revving 355 with 6" rods, or a 383 stroker??
Need advice so tell me what you think
Old Jun 22, 2006 | 10:19 PM
Hark_z's Avatar
Re: LE3 Heads just in...
383 for bragging rights, nice numbers man.
Old Jun 22, 2006 | 10:27 PM
marshall93z's Avatar
Stock castings....I'd do a 355.
Old Jun 22, 2006 | 10:53 PM
Javier97Z28's Avatar
Moderator
355 with 6" rods.. but I'm biased
Old Jun 23, 2006 | 02:08 AM
LT1Squirrel's Avatar
QFT
Old Jun 23, 2006 | 02:20 AM
blackz97's Avatar
355 is a lot of fun ;-)
Steve
Old Jun 23, 2006 | 02:37 AM
Daniel6718's Avatar
355 and shift at 7000...mayb a few psi on that
Old Jun 23, 2006 | 08:04 AM
MeanGreen97Z's Avatar
The 355....
Old Jun 23, 2006 | 09:15 AM
bowtiethunder's Avatar
NICE! What do you want out of the car? I'd go stroker if driveability was more important, if the budget allowed it of course.
Old Jun 23, 2006 | 10:19 AM
Zigroid's Avatar
what do you like? alot of torque or high revving?
if you like alot of torque go with a 383.
if you like high revving horsepower go with a 355.
even lloyd's best LT1 heads will choke a 383 where a 355 will happily continue on to 7000 rpm.
those are really nice numbers. they're similar to my heads up to .500 lift then yours take off. cant beat lloyd's work!
Old Jun 23, 2006 | 10:43 AM
ulakovic22's Avatar
Agreed. You could put together a very nice 355 with those heads.
Old Jun 23, 2006 | 10:51 AM
Colin91Z's Avatar
Nice #s
And I agree with most of the others....
Stock castings--------> High-reving 355
Old Jun 23, 2006 | 01:07 PM
Speed Density's Avatar
Buddy of mine did a pair of stock castings looking damn near close to what you have on a 383, need i say more.
Old Jun 23, 2006 | 03:04 PM
Jlo's Avatar
Jlo
Well, my main goal was to hit 11's on motor as streetablity is no concern anymore. I did get my intake fully ported by Lloyd and the custom grind from Bret B. which is the LE3 cam. I did however plan on using nitrous to get me in the 10's 100-200hp shot. I'll just build an engine that can help me reach my goal. I guess half of you guy's would really like me to build a 355 huh??
Old Jun 23, 2006 | 03:09 PM
Jlo's Avatar
Jlo
Also, what are you 355 guy's running in the 1/4 with a simular set up??
