LE3.2/LE2 Guys HELP!!! 383
Old Jun 26, 2007 | 12:13 AM
Maro Boy Ken's Avatar
My gosh darn vehicle runs like ****. Its seems to be misfiring even after a base tune.
Spark wires on correct
opti has maybe 18k on it
coil could be bad
injectors on correctly
96 opti can only go on 1 way.
Shoot me some suggestions
Before the tune it would never idle on its own, and it did for the first time today. Also my ses light flashes.
tune: o2 delete, adjusted for bigger injectors, thats all i know of.
all suggestions may help
Old Jun 26, 2007 | 12:18 AM
Javier97Z28's Avatar
Moderator
Is your exhaust on the car already? If not, where are your O2's in relation to the open air behind them...
Old Jun 26, 2007 | 12:31 AM
All i have on the car so far is long tubes with the longer o2's connected. Also could incorrectly adjusted rockers be the cause of sputtering or msfire?
Old Jun 26, 2007 | 12:34 AM
speed_demon24's Avatar
You need a good tune, not a rear 02 delete tune. And if you are running open headers fresh air is hitting the 02's causing them to read incorrectly.
Old Jun 26, 2007 | 12:40 AM
Moderator
Try unplugging the O2's and see how it runs.
Old Jun 26, 2007 | 04:35 AM
smoknta's Avatar
You cant run open headers in closed loop. To much fresh air by the O2's will cause a false lean condition and cause the PCM to add more fuel. Put some extentions on those headers.
Old Jun 26, 2007 | 10:51 PM
I put my y pipe on and it began to run a lot better I still need a bit more fuel on the bottom end. I can start and it would idle on its own but after driving it would die. It also needs just a touch of gas to start. I'm guessin a little bit of timing adjusted also.
Thanks for your suggestions.
Last edited by Maro Boy Ken; Jun 26, 2007 at 10:53 PM. Reason: I had to say thank you.
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
spearous
Jan 12, 2015 11:03 AM
Red97LT1
Aug 7, 2002 05:45 PM
