LE3.2/LE2 Guys HELP!!! 383
My gosh darn vehicle runs like ****. Its seems to be misfiring even after a base tune.
Spark wires on correct
opti has maybe 18k on it
coil could be bad
injectors on correctly
96 opti can only go on 1 way.
Shoot me some suggestions
Before the tune it would never idle on its own, and it did for the first time today. Also my ses light flashes.
tune: o2 delete, adjusted for bigger injectors, thats all i know of.
all suggestions may help
coil could be bad
I put my y pipe on and it began to run a lot better I still need a bit more fuel on the bottom end. I can start and it would idle on its own but after driving it would die. It also needs just a touch of gas to start. I'm guessin a little bit of timing adjusted also.
Thanks for your suggestions.
Last edited by Maro Boy Ken; Jun 26, 2007 at 10:53 PM. Reason: I had to say thank you.
