LE2, LE3 what's difference
Old Jun 29, 2006 | 10:54 AM
  #16
user 647483's Avatar
Re: LE2, LE3 what's difference
Originally Posted by Gripenfelter
I have the LE2 heads and cam with the LE4 intake. http://www.homemadeturbo.com/tech_projects/itb/
Above link is not my car.
Old Jul 18, 2006 | 09:58 AM
  #17
kaoticcamaross's Avatar
I was reading the websites package discription and I believe it was said the LE3 was better for a 355 but on the site it says you should go with a 3500 stall and a 4.10 rear end. So would this not be the package for a 355 with 3.42's and a 3200 stall?
Old Jul 18, 2006 | 10:03 AM
  #18
blackztpi's Avatar
Originally Posted by cleangene
Ok that makes more sense, but why can't you put LE3 heads on a stock block, it's not that much difference in power.
oh my gosh...please please say you know where power is made in an engine.
Old Jul 18, 2006 | 10:10 AM
  #19
"White Knight"'s Avatar
LOL good job way to get everyone riled up with the LE4 Bret lol
That would make what a stock short block hit 500rwhp.
I'm still waiting for his secret heads......they are suppose to make 500rwhp @ 4,000 rpm on a stock bottom end. I have a feeling I'm going to be waiting a long time...
Old Jul 18, 2006 | 10:11 AM
  #20
SStrokerAce's Avatar
Right, the LE2 package would work much better for you.
The LE packages aren't like the next stage of parts you buy for your car on GT4, they are actually matched to a certain car setup. You don't want to go real big with the heads and cam when your car is not matched up to it because it will end up slower, not faster.
Bret
Old Jul 18, 2006 | 10:46 AM
  #21
Bret if I'm gonna be running a sts set up on this 355 would the LE2 still be a good idea or would the LE packages not be a good idea?
Old Jul 18, 2006 | 11:04 AM
  #22
custom forced-induction grind
Old Jul 18, 2006 | 11:15 AM
  #23
Yeah we can just build a turbo cam for it.
Bret
Old Jul 18, 2006 | 11:18 AM
  #24
So the LE2 but a turbo cam
Old Jul 18, 2006 | 03:51 PM
  #25
cause4panic's Avatar
Forced induction makes up for heads that are more restrictive. sts + stock heads + turbo cam if you are not going totally wild with the build
Old Jul 18, 2006 | 03:57 PM
  #26
Actually I'm trying not to go totally wild on the build. I want this car to still be as close to daily driveable as possible.
Old Jul 18, 2006 | 05:35 PM
  #27
Well the thing that ported heads do is minimize the flow restriction and so the motor will allow more CFM to be pumped into it at lower boost levels. Boost PSI is basically backpressure.
Bret
Old Jul 19, 2006 | 10:00 PM
  #28
Josh'95Z28conv's Avatar
I have an LE4 custom cam with my special LE3 heads. Too bad the temp is in the mid 80's at midnight, and I dont have the motivation to brave the heat and get the thing running.
I need to knock a hole in my garage wall and install a window ac unit. Then maybe Ill finish this before summer ends
9t4lt4z28
Oct 2, 2015 10:28 AM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
