View Poll Results: Comp Pro-mag...How many turns past zero lash?
1/4 turn past zero lash
11
73.33%
1/2 turn past zero lash
26.67%
Voters: 15. You may not vote on this poll
Comp. Pro-mag correct lash setting........
Old Jul 18, 2006 | 11:12 AM
wrd1972's Avatar
I have run 1/2 turn past zero lash (non engine running) and not have any issues. Engine ran quiet and strong. This is what Comp reccomends for the Pro-mag rockers. I am also running the Comp 7/16" studs.
Many state that they adjust to 1/4 turn past zero lash.
Please post your thoughts.
Old Jul 18, 2006 | 11:15 AM
matLT1's Avatar
Re: Comp. Pro-mag correct lash setting........
It depends on your rpm range. 1/2 turn is as tight as I'd go but if you want to rev it higher (say 6K or more) I'd tighten it to 1/8-1/4 turn.
Old Jul 18, 2006 | 11:33 AM
stereomandan's Avatar
If you have stock lifters, and 3/8" studs, then 1/2 turn is optimal.
If you have stock lifters, and 7/16" studs, then 3/8 turn is optimal.
The difference is due to the thread pitch on the studs being different. Adjusting them this way will put the correct amount of preload on the lifters.
Dan
Old Jul 18, 2006 | 12:00 PM
Javier97Z28's Avatar
Moderator
I'm doing 1/4 turn with 7/16" ARP studs in a 7k RPM revver.
Old Jul 18, 2006 | 12:14 PM
Assuming this thread is about Comp Pro Mag rocker arms, IMO, the rocker has nothing to do with the desired lash setting. A rocker arm will perform the same, no matter what the lash. Lash is set by lifter type or desired lash for performance reasons.
Old Jul 18, 2006 | 12:22 PM
"White Knight"'s Avatar
I just set mine to 1/4 will let you know in a couple weeks.
Old Jul 18, 2006 | 02:31 PM
JustNO's Avatar
exactly.
Old Jul 18, 2006 | 03:43 PM
We all know what he means. Not to mention the title is not one sentence. He used ... to seperate the two.
Comp Pro-mags installed, what a pain. How many turns past zero lash?
^This could be what he is saying. You use ... to fill in the middle.
Old Jul 18, 2006 | 05:30 PM
JustNO's Avatar
You are right, but he didn't let us know about lifters right?
Old Jul 18, 2006 | 09:49 PM
firebirdStud's Avatar
Well, I am using comp 850 lifters, started at 1/4 turn past zero, and they were kinda loud. But, my tuner said loosen them to 1/8 turn and I will pick up some power, man are they loud. But, it doesn't bother me, I am more worried about them being too loose. But, he assures me its ok to do this.. I am using the bigger studs too.
Old Jul 19, 2006 | 07:26 AM
wrd1972's Avatar
Sorry, I have stock lifters.
Old Jul 19, 2006 | 06:01 PM
Dave88LX's Avatar
1/16-1/12 turn, with Pro Mag's and Comp R lifters.
Old Jul 19, 2006 | 06:08 PM
1racerdude's Avatar
If ya have them 1/8th turn TIGHTER than"0" they shouldn't be noisy.
Do it with the engine running and "0" is when they STOP clacking and making noise, then 1/8 preload.
Old Jul 19, 2006 | 09:54 PM
Talking Re: Comp. Pro-mag correct lash setting........
Yep, I do it running. I do one bank at a time, and I have someone start it, then I adjust each one out until it clacks, then I tighten it down with my finger until it stops. Then I do the next and next until the bank is done, then I kill the motor and set the preload. I do this to keep oil off the headers.
I may try to do each one individually. Like, back it off, then tighten it with my finger until it stops clacking, then take the wrench and do the 1/8th turn, then move on to the next... just alot of run time to throw oil everywhere...
What do you think?
Old Jul 19, 2006 | 10:15 PM
1racerdude's Avatar
Get ya a regular valve covers and cut the top the full length of the top of the cover minus a couple of bolt holes. Cut the sides down to almost the vertical side on the bottom. Bend the cut part back and trim some height and smooth the edges. Bolt um on and set them while they are running.
Ya need to set the preload with it running to get the lifter to back down. Otherwise they will all hold the valves open and possibly damage something or make it hard to start.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
