LE2 H/C/I is finished!
Old Oct 24, 2008 | 07:42 PM
Green96Z's Avatar
http://s238.photobucket.com/albums/f...ent=Movie2.flv
I finally got her running! I still need to break in the cam, change the oil, and retorque the header and intake bolts, but it runs. It sounds like a sewing machine under the hood (which I expected) but I'm gonna pull the valve covers next week and make sure they are all still tight.
Lots of thanks to everyone that helped, especially Lloyd Elliot and Shoebox!
Old Oct 24, 2008 | 07:46 PM
user 647483's Avatar
Hell yeah! Bet you can't wait to get her out on some open road and let it loose
wheeeeeeeeeeeeeeeeee
Old Oct 24, 2008 | 08:17 PM
bombebomb's Avatar
Im confused, I was under the impression HR cams did not need broke in? Thanks for the sound of the "sewing machine" iv been wanting to hear that.
Old Oct 24, 2008 | 08:32 PM
SS RRR's Avatar
Cam does not have to be run in with a hydraulic roller valve train.
Old Oct 24, 2008 | 09:06 PM
Green96Z's Avatar
I know that, but I plan on taking it easy until all the lobes and journals "mate" to the lifters and bearings. It's probably not needed, but I figure since I spent all the money and time doing it I shouldn't try to break it in the first week.
I really can't . I plan on getting it dynoed in a couple weeks too.
Old Oct 25, 2008 | 02:15 AM
dueno's Avatar
I've noticed you live in CA. Do you actually have the LE2 cam, or the LE emissions cam that is in your sig? I was under the impression that an LE2 cam wouldn't pass smog in CA. That is if you are actually planning on passing smog... I'm researching a little on CA smog-able setups, looking forward to seeing what you dyno!
Old Oct 25, 2008 | 02:48 AM
Green96Z's Avatar
It's a smog legal cam. Slightly smaller than a CC503, and Lloyd assured me it would pass smog. I don't plan on staying in CA much longer, but I will still have to pass smog again soon, so my hopes are up.
Old Oct 25, 2008 | 07:57 AM
NightTrain66's Avatar
sounds pretty good for an emissions cam.
make sure the rockers are about 1/8 of a turn past zero lash. Any tighter and it can effect top end power.
Let us know how it does on the dyno.
Lloyd
Old Oct 25, 2008 | 09:03 AM
Z-RATED94's Avatar
Good for you. Bet it's a fun ride, since it's a stick. As stated, let us know what it puts down for numbers when you have it squared away.
Old Oct 25, 2008 | 11:20 AM
SS MPSTR's Avatar
congratulations! break it in and bring it out to Fontana on November 1 and 2 for some 1/4 mile track numbers.
Old Oct 25, 2008 | 11:40 AM
krillformula's Avatar
Sounds good! I know that sewing machine sound
Old Oct 25, 2008 | 02:14 PM
Sickynar9's Avatar
Hey just curious where you got the guides for you spark plug wires. I really need some like that. Thanks
Old Oct 25, 2008 | 02:41 PM
Green96Z's Avatar
Thanks guys, I love how it sounds.
Sickynar9, the looms are Made For You and I got them from thunderracing.com.
Lloyd, I went 1/2 turn for my preload, do you think I should go back and set my lash to 1/8? These are stock used lifters BTW. Thanks.
Old Oct 25, 2008 | 03:15 PM
ZDriver96's Avatar
Mine sounds like a sewing machine too.. 1.6 pro mag roller rockers... It throws false knocks too unfortunately... The LE2 heads and Cam runs awesome... Drag radials are struggling to keep up with them
Trying to get it tuned out right and then onto the dyno she goes... very happy with the LE2 setup... Glad yours is running good too..
Old Oct 25, 2008 | 05:19 PM
not sure if that will help the noise any but it will amke it run better if you re adjust thema nd set them at 1/8 past zero lash.
Maybe you will find some out of adjustment when you go back through them.
Lloyd
