LE2 Dyno #'s
Old May 14, 2006 | 08:33 PM
  #61
Hark_z's Avatar
Re: LE2 Dyno #'s
437/444
Old May 14, 2006 | 10:11 PM
  #62
Loadre's Avatar
Re: LE2 Dyno #'s
Originally Posted by Josh'95Z28conv
I prefer to use a leakdown tester and put compressed air into the cylinder to hold the valves up. I dont like the idea of putting rope into my engine.
You use the thick tight-wound stuff. I don't like the idea of a compressor locking up or having a power failure and dropping a valve. To each their own I guess.
Plus it's 50x easier than trying to thread a hose into the spark plug hole.
Old May 14, 2006 | 10:14 PM
  #63
Javier97Z28's Avatar
Moderator
Re: LE2 Dyno #'s
I don't use either, just bring the piston you are working with up to TDC, if the valve seals are good they will hold the valve up enough while you are working with it and there's no danger of dropping a valve into the cylinder.
Old May 14, 2006 | 10:17 PM
  #64
Loadre's Avatar
Re: LE2 Dyno #'s
What if you've got the springs off because you're changing valve seals? haha
Old May 14, 2006 | 10:30 PM
  #65
Moderator
Re: LE2 Dyno #'s
Not a problem, most of the pain is keeping them "up" to put the springs back on usually.. taking them off is the easy part.
Bring piston to TDC, remove spring, remove valve seal, replace valveseal, pull valve up, replace spring. With the ls1tech tool mentioned earlier we've found it to be the easiest way.. it ain't cake, but it's still easier.
Old May 14, 2006 | 10:33 PM
  #66
Loadre's Avatar
Re: LE2 Dyno #'s
haha I was just razzin you.
That's one reason I like the screw type for putting the springs back on. The LS1tech tool is a PITA for putting springs back on. I about shot myself the first time I tried it.
Old May 14, 2006 | 10:43 PM
  #67
Moderator
Re: LE2 Dyno #'s
There's a trick to the LS1tech tool that gets the spring on quickly.. I don't even know how to do it, but my buddy who I do cam installs with does, so I let him do that crap while I button up the rest of the car Lucky him
Old May 14, 2006 | 11:59 PM
  #68
396D1SS's Avatar
Re: LE2 Dyno #'s
any pics of the car?
Old May 15, 2006 | 12:58 AM
  #69
zx1216's Avatar
Re: LE2 Dyno #'s
With the piston at tdc the valve will only drop about a half inch and hit the piston. This allows you to change the seals
Old May 15, 2006 | 10:27 AM
  #70
Loadre's Avatar
Re: LE2 Dyno #'s
Yup this method works too. But I found it is about the same amount of work to throw rope in there and keep the valve at full height, which every little bit helps when reinstalling springs. It's all just personal preference I guess.
Old May 15, 2006 | 12:22 PM
  #71
FastLt1's Avatar
Re: LE2 Dyno #'s
It is next week where are the numbers?
Old May 31, 2006 | 08:43 PM
  #72
user 647483's Avatar
Re: LE2 Dyno #'s
413 rwhp 429 rwtq
Old May 31, 2006 | 10:13 PM
  #73
silverz28's Avatar
Re: LE2 Dyno #'s
I think those are my old heads Lloyd. Sorry to hear about the springs, the heads only had about 800 miles on them. And I didn't touch them. ie, set new spring hight.
Old May 31, 2006 | 10:15 PM
  #74
silverz28's Avatar
Re: LE2 Dyno #'s
Oh, my guess is 385hp
Old May 31, 2006 | 11:06 PM
  #75
396D1SS's Avatar
Re: LE2 Dyno #'s
running on 7 cylinders
