le2 bottom end setup
Old Sep 30, 2005 | 08:42 PM
jz3082's Avatar
I've got 5.7" SIR eagle rods and a stock crank, going NA. I'm going with the LE2 package from lloyd and was wondering what pistons would work well. I was looking at SRP's or Mahle's looking to get around 10.8-11.5:1 compression. I can find the pistons from srp part number 138081 but i can't find mahle pistons that would work. Also does anyone know the combustion chamber size of le2 heads so i can figure out the compression ratio's for pistons? And does anyone know which mahle pistons would work? Thanks.
-Jeff
Old Oct 1, 2005 | 02:49 PM
speedmiser's Avatar
Re: le2 bottom end setup
Try emailing Lloyd directly on the head cc. He usually responds fairly quickly.
Old Oct 1, 2005 | 03:14 PM
89385formula's Avatar
I would think that the CC's of the LE2 heads would be in the neighborhood of 55-57cc's. Are you having the block decked as well? This affects your computations for you compression ratio. I would go with Mahle over SRP for simple fact that they cost the same and come coated. I believe the part number for the Mahle piston you are looking for is SBC550030F05.
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Bignasty85
Mar 3, 2015 04:05 PM
Killer94z
Jan 13, 2015 12:06 PM
