Le2 .60 over hmm...
Old Sep 26, 2006 | 11:46 AM
red_94z's Avatar
Le2 .60 over hmm...
Hey i was just wonderin what kinda numbers i can expect from a LE2 head cam package with all the bolt ons* and bored .60 over (all the appropriate things like forged crank I beam rods etc...) is gonna do for me. Car weighs about 3500 and planin on 4.10s with a/b a 3,500 rpm stall.(Stock rear n what not till it breaks then 12 bolt) One more thing its same car as below ecept got a stall and it runs 8.50s.
Old Sep 26, 2006 | 12:02 PM
Sweetred95ta's Avatar
Re: Le2 .60 over hmm...
Why .060 over?? That's pushing it on a stock block. You're not going to see any more performance versus .030 over.
Old Sep 26, 2006 | 12:07 PM
SStrokerAce's Avatar
yeah just stick with the .030" over and a stock crank with forged pistons and rods, that will be more than enough.
Bret
Old Sep 26, 2006 | 04:59 PM
red_94z's Avatar
ok lets say .030 over. Well what sorta numbers can i get from that? Any more opinions on the set up? Anyone?
Old Sep 26, 2006 | 08:31 PM
If everything is right on, somewhere around 400 rwhp.
Old Sep 26, 2006 | 10:54 PM
reamo04's Avatar
talked to a buddy of mine that has a '94 formula with stock heads/bottom end, moroso cold air kit, cc306 cam, pacesetter longtubes, pro-built 4l60e tranny, 4.10 gears in the stock rearend, 2800rpm stall, drag radials and a tune. His dyno numbers were 351rwhp/364rwtq and best track time is 12.05 @ 113mph, 1.7 60ft.
so i'd say that you would be faster than him being a 355....
Old Sep 27, 2006 | 11:16 AM
red_94z's Avatar
Kewl ill be happy if my car can run that. Is anyone runin a set up like mine if so could ya tell me what kinda times you are running. How much more would the LE3 help my times? I wanna run around 7.50 in the 1/8th and what kinda tires would ya reccomend to hook it up?
Old Sep 27, 2006 | 11:21 AM
WS Sick's Avatar
You could also up the compression up a half point or more and make a little more power simply from that.
Old Sep 28, 2006 | 06:02 AM
mebanditws6's Avatar
Should be close to 400rwhp give or take, even through an auto. Lloyd has differing variations of his cams that can make or break some power. He's also found a new way to get more flow out of his LE2 heads. Make sure and get as tight as quench as you can without seriously jeopardizing piston/valve clearance and shoot for low 11's for compression.
Jason
9t4lt4z28
Oct 2, 2015 10:28 AM
Schul365
Aug 25, 2015 05:47 PM
1973Camaro
Classic Engine Tech
Aug 4, 2004 10:34 AM
madwolf
Oct 3, 2003 11:00 PM
afterimage ss
Jan 29, 2003 01:06 PM
