Le2 383 1st Dyno Run (mail Order Tune!)
Old Apr 12, 2008 | 12:11 PM
palehorse77's Avatar
Cool Le2 383 1st Dyno Run (mail Order Tune!)
Not bad for a mile above sea level. Needs a little fuel up top and idles inconsistently but otherwise tip top!
Next a dyno tune just didn't have time today.
Thanks to:
Loyd, Geddes Machine, PCMForless, David Bills, Injuneer and the countless others input on this forum!
Old Apr 12, 2008 | 12:20 PM
96capricemgr's Avatar
dyno runs are corrected for weather and elevation
Old Apr 12, 2008 | 12:29 PM
Lightbulb
You're right. That makes sense.
http://www.alteredatmosphere.com/technical/dyno.php
That took a little wind out of my sails. We'll see what the extra fuel up top will do? A wonder how much is left in her? Just started the thing two weeks ago so I haven't really touched anything yet.
KJA
Old Apr 12, 2008 | 12:33 PM
Also, need to get it to the track. Today is opening day here in sunny Colorado so I didn't want to fight the crowd. I still need the lowering brackets welded in as well. Otherwise ready to go tho.
Kirk
Old Apr 12, 2008 | 12:45 PM
stereomandan's Avatar
Did you get a reading on your a/f?
Dan
Old Apr 12, 2008 | 12:55 PM
northdakota93z28's Avatar
at sea level he would have more hp.
Old Apr 12, 2008 | 01:03 PM
That depends on the accuracy of the dyno setup and corrections used.
Old Apr 12, 2008 | 01:27 PM
He did wide band A/F ratio and first run it was very lean. 2nd and 3rd runs looked much better but still looking for fuel up top ( like 5k and up).
Unfortuneatly I didn't get the file yet. He's going to email me. I just scanned the hard copy he gave me.
They were off to the track.
Running:
" FelPro 1074 head and full o-ring/gasket set $248
ACL performance rod and main kit $95
Durabond cam bearing set $13
Brass Plug kit $12
ARP main studs $80
Cloyes roller #1345 timing set $100
Callies 4 bolt main caps $200
Compstar crankshaft forged steel internal balance $600
Core block $100
ARP head bolt set $62
Proff Products SFI Balancer $199
Proffessional Products Polished 52mm tb $180
Comp Cam Rods 7.2 measured ~$100
GM lifters and Guides $255
GM new oil drive gear $40 (Don't reuse)
MSD Super Conductor wires OVC $130
30# SVO injectors $200
Ported Intake $200
Jet Hot Ceramic Coated LT's w. Flowmaster Y $500
Mahle Power Pak -5cc $400
Eagle Forged H beams $400
Comp Cams 1.6 RR $200
Used Heads for LE $200
LE2 Headwork & LE3Cam $1800 w. shipping
Machine work for above ~$2400
PCMforless update $50 (~$200New)
Front Shocks & Springs and 98+ Brakes $500
Urethane Engine / Trans Mts $75
02 Extensions for LTs $40
Pilot Bushing *NOT Bearing* $5 "
These 30# my be maxed on pw? We'll see
Kirk
Old Apr 12, 2008 | 01:36 PM
speed_demon24's Avatar
Running:
Brass Plug kit $12
ARP main studs $80
Core block $100
Ported Intake $200
Kirk
I'm making more power than you with racetronix 32lb injectors so I doubt yours are maxed out, expecially since you are a mile above sea level and your uncorrected #'s are probably below 400rwhp. Are you still running the stock fuel pump?
Old Apr 12, 2008 | 02:17 PM
Yea stock fuel pump.
Old Apr 12, 2008 | 02:32 PM
The_Bishop's Avatar
That might be a problem.
Old Apr 12, 2008 | 03:46 PM
What are the limits on the stocker?
THanks
KJa
Old Apr 12, 2008 | 04:55 PM
89385formula's Avatar
The graph appears to be SAE corrected by the scales on the side.
Old Apr 12, 2008 | 05:18 PM
Yes I know that, thats why I said he probably made <400rwhp uncorrected since he said he's a mile above sea level... His uncorrected #'s are what he should use to determine his fuel demand since that is what the motor is actually putting out.
Old Apr 12, 2008 | 05:25 PM
RedScreaminMachine's Avatar
Damn good numbers! That'll take the wind out of the sails of a few LS1 owners!
