LE1 with stock injectors
Old Nov 25, 2006 | 08:33 AM
bingo's Avatar
I just put a 355 with an LE1 h/c package in my car. I had my computer programmed for #30 injectors. Here is the problem... One of the injectors is causing a miss. Would it hurt to run the factory injectors until I can afford new 30s? I figure this will hurt performance, but will it hurt the engine?
Old Nov 25, 2006 | 10:03 AM
Z-RATED94's Avatar
Going back to the stockers would be a no no. Way to lean to be safe. If you know which one it is why not just replace the one?
Old Nov 25, 2006 | 10:19 AM
dre2013's Avatar
ditto...im sure you could find a single 30lb injector for a decent price...alot of people are running those
Old Nov 25, 2006 | 10:27 AM
bingo's Avatar
I am pretty sure it is more than one. It is an older(6 years) set of SVO injectors. I really need to replace all of them. I am certain the bad injectors are holding me back. It has a miss at idle that smooths out in the upper RPMs. The reason I believe it is the injectors is because I tried them in my old motor and they had a slight miss. The old engine did not miss with the stock injectors. Does anyone know anything about Summit injectors? Who makes them? Will this miss cause any long term problems?
Old Nov 26, 2006 | 09:17 PM
1_badz28's Avatar
i belive Lloyd recomends going to 36lb injectors for that set up to give u the best performance go with the svo injectors
Old Nov 26, 2006 | 09:40 PM
He recommends 30#/HR injectors with the LE1 package.
Old Nov 26, 2006 | 10:06 PM
95LT1conv's Avatar
there is a set of 30# svo's in the for sale section for $180 obo
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
