LE1 questions
Old Oct 1, 2006 | 02:01 AM
ajlew9428's Avatar
LE1 questions
Ive got 115000 miles on my engine, and thinking of getting the le1 package. Some quetins I had were does the cam have the dowel pin needed for my 94? should I buy the iron lt1 heads? when I insyall new head gaskets, will I need to change my pushrods? Do I have to get rid of EGR, Etc? what are some good mail order tunes that work well eith this package?should I upgrade the rockers?springs? I apolagize for all of the questions, and long post. I felt it would be a lot easier to just sum it up in one post.
Old Oct 1, 2006 | 02:22 AM
wrd1972's Avatar
Re: LE1 questions
You will get the LE1 cam for 1994 spec.
Lloyd reccomends the thinner Impala head gaskets.
Why would you want ported iron heads instaed of aluminum
50/50 chance on the pushrods, you will need to check geometry to make sure.
No you dont have to lose the EGR.
PCM4less.com and madz28.com are familiar with LE specs and will prived a decent tune.
Old Oct 1, 2006 | 02:26 AM
Joe B's Avatar
Re: LE1 questions
The LE Cams are all custom ground, and will have the correct dowel pin length for your year car(just make sure Lloyd Knows).. and it's a good idea to double check the dowels length to make certain it's correct.......I would always go with aluminum heads over Iron(lighter, easier to repair, and, you can get away with a little higher compression with them before detonation, ECT....).......If you go with a thinner head gasket like most of us do to get a small compression boost(or atleast break even after the extensive chamber work Lloyd does), then yes, you "may" have to change your pushrod length, "NOT always", but this needs to be one of the last things you check after your new heads and head gaskets are on the car(every engine is different in what it needs)...on mine, the stock 7.2 length pushrods were the perfect ones to give the right rocker geometry even though I went with the Much thinner Impala head gaskets........you can keep or get rid of the EGR....since it dosn't hurt performance, I'd keep it, but you can choose to get rid of it to clean up your engine's looks a bit if you like.......Bryan Herter from PCM's for less is VERY familiar with Lloyd's packages and will be able to get you VERY close on a mail order tune.....thats who did mine and it's pretty darn close......there are a couple others, but for mail order I like Bryans tuning work.....hope this helps you some........you can't go wrong with Lloyds head and cam packages......Mine was done about a year ago, and it's just as fun to drive as the day I fired it up after the engine mods............good luck........Joe
Old Oct 1, 2006 | 11:40 AM
1995greenTA's Avatar
Re: LE1 questions
You need to make love to the search feature on this site...
Old Oct 1, 2006 | 03:23 PM
SStrokerAce's Avatar
Re: LE1 questions
Listen to Joe B, he knows what he is talking about.
Bret
Old Oct 1, 2006 | 04:48 PM
ajlew9428's Avatar
Re: LE1 questions
thanks for all of the help. The only reason I was talking about iron over aluminum was B/c my uncle has a 96 Z, and he said after he did a custom head, cam package(not lloyd elliot)one of his spark plugs blew out, and flattened the threads,but I just assumed that he didnt thread it right, or it wasnt all the way in. He swore that it was though
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
