LE1 cam ... Leave EGR alone? Disable it? Does it matter?
Old Mar 28, 2006 | 08:28 PM
sabre81's Avatar
Should a heads/cam swap call for the deletion of EGR or should i leave it as it is? It is functioning correctly at the moment,
Old Mar 28, 2006 | 11:30 PM
ulakovic22's Avatar
Re: LE1 cam ... Leave EGR alone? Disable it? Does it matter?
Leave it alone if everything if functioning correctly. Most of the time when you put on a less restrictive exhaust there is obviously less backpressure and the EGR often times doesn't work properly and you get the dreaded SES light. The EGR recirculates exhaust gas and decreases the chance of detonation.
Old Apr 1, 2006 | 03:57 PM
sabre81's Avatar
Well, i hear cam surge can be minimized by deletion of the EGR system due to the overlap of the cam. From what i've read, LT4 engines don't have EGR systems because the overlap of the cam allowing "natural" egr.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
Wicked
Jul 25, 2002 04:19 PM
Redbird
Jul 20, 2002 06:08 AM
