le1.5 set up
Old Oct 10, 2006 | 06:22 PM
1_badz28's Avatar
le1.5 set up
what's up everyone, i've got le1.5 set up with full bolt ons hit 375rwhp 358rwtq on midlengh, 52 t/b, 36svo injectors. Upgraded to longtubes, ported intake, and 58 t/b what power gains am i looking at thanks josh.
Old Oct 10, 2006 | 06:51 PM
seawolf06's Avatar
Re: le1.5 set up
Is it the LE2 heads with LE1 cam or vice versa? The more the heads are ported the more you'll get from the intake and TB. Did you port the intake runners until they broke through and then welded them back? That's really the only way to get any noticible gains from the stock intake from what I've heard. I'd say a little more peak hp and a little less low end for the LT's, but they say that you get more area under the curve, which is what you want more than anything. Get it on the dyno and let us know, then post track times, since that's what REALLY matters.
Old Oct 10, 2006 | 07:04 PM
1_bad t/a's Avatar
Re: le1.5 set up
Its a le1 head w/ le2 cam, the intake is ported by loyld.
Old Oct 10, 2006 | 07:10 PM
seawolf06's Avatar
Re: le1.5 set up
Don't think the TB will help any, in fact many people have had more problems with them than they're worth, except for AS&M. I'm sure Lloyd did your intake right. He knows his setup better than anyone, what did he tell you to expect?
Old Oct 10, 2006 | 07:21 PM
1_bad t/a's Avatar
Re: le1.5 set up
380's maybe in the 390's.
Old Oct 10, 2006 | 07:22 PM
seawolf06's Avatar
Re: le1.5 set up
That would be really good through an A4.
Old Oct 10, 2006 | 10:39 PM
SStrokerAce's Avatar
Re: le1.5 set up
I've seen 400rwhp with that. Did you get them straight from Lloyd or used?
Bret
Old Oct 10, 2006 | 11:06 PM
1_badz28's Avatar
Re: le1.5 set up
Bret
i got them from Lloyd so he recomended to up the t/b to 58mm
Old Oct 10, 2006 | 11:23 PM
Re: le1.5 set up
Ok cool so you have the springs to handle that cam, that should work killer.
Bret
Old Oct 10, 2006 | 11:29 PM
ulakovic22's Avatar
Re: le1.5 set up
The LT's will help the most over your midlengths. The ported intake is worth about 8-10 peak a little under the curve. The TB probably won't help a bunch but it will help. You can't really over TB a LT1 intake cause it's pluemn volume is so anemic. I say that you will be right around 390-395 and with the LT's it will feel smoother on the low end cause of the better scanvaging, plus that's what the cam is designed for.
Old Oct 10, 2006 | 11:36 PM
1_badz28's Avatar
Re: le1.5 set up
Bret
btw thanks Bret , the cam sounds and feels awsome
Old Oct 10, 2006 | 11:40 PM
1_badz28's Avatar
Re: le1.5 set up
Hopefully we hit that mark should install everything by this weeks end and take it for tunning next weekend thanks bro.
Old Oct 11, 2006 | 06:19 AM
NightTrain66's Avatar
Re: le1.5 set up
changing all of that at once should get you 390-400 RWHP as long as it is tuned for the changes.
Lloyd
Old Oct 11, 2006 | 07:46 AM
1_badz28's Avatar
Re: le1.5 set up
Lloyd
Thanks Lloyd , btw i did recive the intake last night , and yes everything will be changed all at once.
HectorM52
Jul 30, 2017 11:46 AM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jan 23, 2015 01:13 PM
