Le Cams
Old Sep 3, 2007 | 10:13 PM
Steve Buckley's Avatar
Le Cams
Will he sale a cam matched for my combo o do you have to purchase his kits?
Old Sep 4, 2007 | 01:21 AM
JP95ZM6's Avatar
I believe Mr. Elliot only sells the LE cams with his packages; that is what those cams are designed for; the heads and cams compliment each other well. Last I knew, Lloyd does not design or sell custom cams. Sounds like you are looking for a custom cam grinder. Bret Bauer, the guy who specs the cams for the LE packages, also sells custom cams, so it is possible to essentially get a cam designed for your package from the same cam designer LE works with, if that's what you mean.
Old Sep 4, 2007 | 09:44 AM
Z-RATED94's Avatar
As mentioned, Bret does the cams for Lloyd. Sometimes he's easy to get a hold off, sometimes not.
Old Sep 6, 2007 | 02:31 AM
SStrokerAce's Avatar
e-mail is the easiest way......
Old Sep 6, 2007 | 07:40 AM
user 647483's Avatar
That's how I got mine
Along with some great supporting mod goodies.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
