Le Cams
I believe Mr. Elliot only sells the LE cams with his packages; that is what those cams are designed for; the heads and cams compliment each other well. Last I knew, Lloyd does not design or sell custom cams. Sounds like you are looking for a custom cam grinder. Bret Bauer, the guy who specs the cams for the LE packages, also sells custom cams, so it is possible to essentially get a cam designed for your package from the same cam designer LE works with, if that's what you mean.
