LE 1 dyno nubmers with new BRE 2.3 cam
Old Nov 23, 2005 | 01:00 PM
  #31
ken9c1SS's Avatar
Re: LE 1 dyno nubmers with new BRE 2.3 cam
cant wait until my Le2 package arrive next week!
Old Nov 23, 2005 | 01:18 PM
  #32
1SlowFormula's Avatar
Originally Posted by Split
The heads are used, i bought them off of a guy that had them sent to Lloyd for porting. Thanks i am content with the numbers, for now. As you can see from the graph it flatens off up top, but never drops off. I feel that something is restricing the air flow into the motor, because it acts like it cant make any more power. If it made peak power it would fall off afterwards, looking at the graph it doesn't. I am going back and rechecking my work, it has to be something small.
I dont have the flow numbers the guy i bought them from has them still. I how straight from Lloyd that they are his heads from a year and a half ago. The motor they came off of had a piston let go, resulting in a pitted head surface. I had to have the heads milled more than i wanted to clean them up.
How much meat was removed? What is your final static compression ratio after the mill work?
Thanks,
Old Nov 23, 2005 | 02:18 PM
  #33
Split's Avatar
Thanks,
Edit
Added flow sheet and dyno graph to the first thread
The heads had .013 removed this time, plus whatever Lloyd had to remove when he ported them. Not sure on the static/dynamic compression ratio.
Old Nov 23, 2005 | 04:58 PM
  #34
SStrokerAce's Avatar
Originally Posted by Jeremy95TA
Thats amazing that he's making that kind of power off of LE1 heads and the LE2 cam with a stock displacement.
I wonder what a full LE3 setup with a 396 would get on a 6 speed. I am seriously considering doing that when I mod up.
The cubes are actually a detriment to making HP up high.... cubes make TQ but to make more HP with them you need more head than a LT1 casting can give you.
IMHO the best setup is a 355 with a LE3 setup, that's going to get you the best bang for the buck.
FWIW, the new LE1 heads move more air from .400" lift up, the milling you did to the heads could have caused that since it might have gotten into the intake valve seat.
Guys don't worry about the setups being outdated, these are only small changes that have happened lately to the cams, nothing your going to really notice much, but I keep tweaking the cams and lloyd keeps getting better at the heads.
Bret
Old Nov 23, 2005 | 08:12 PM
  #35
Jeremy95TA's Avatar
Bret
Well ideally I'd like 11.7's (or better) on motor and possibly even 10's on spray. Is this possible with a 355? I know that with more cubes a car is 'more streetable' if you will. The reason I'd like to know numbers is just for a baseline. I know that 415ish rwhp will net you 11's if you can drive and have your suspention which I am working on right now. Suspension before mods for me Would a 383 be more ideal? (sorry for the hijack)
  #36
Jon A's Avatar
Very nice numbers, Shane! On the 400 RWHP line for about a thousand RPM is quite impressive--especially for a stock bottom end!
Now there's an idea!
Old Nov 23, 2005 | 08:26 PM
  #37
OldSStroker's Avatar
Geat minds run in the same gutter...err, think alike.
I like what I've seen so far...
Old Nov 23, 2005 | 08:34 PM
  #38
93camaroLT1's Avatar
Just got back from the dyno
PCm for less tune for LE setups
392 rwhp
371 rwtq
Joe Young (Kryckter) tune
403rwhp
383rwtq
Picked up 12 ft .lb accross the entire rpm range !!!! Thanks Joe for the dyno tune, money well spent.
The car made 398hp at 5600rpm , at 6500 it made 403hp. Something is holding it back on the top end, the car never fell off of the top end. The hp just stayed flat like something was restricting it from making any more. But i was still pleased with the numbers, the torque was really high, for the hp so i know it could put down more if i can get the setup up dialed in. I think 415rwhp is doable.
Thanks Bret for the awesome cam, Joe for the tune, and Lloyd for the heads.
Dyno graph
Flow Numbers
LIFT Intake Exhaust
0.0500 36.6 24.3
0.1000 69.2 48.1
0.1500 99.1 72.5
0.2000 135.2 94.8
0.2500 163.9 115.4
0.3000 191.1 130.5
0.3500 211.2 143.5
0.4000 229.9 153.7
0.4500 239.8 162.6
0.5000 249.3 168.9
0.5500 252.2 173.8
0.6000 258.2 177.7
0.6500 259.2 180.2
0.7000 259.5 181.1
what valve springs and retainers are you running on your LE 1 heads? I was under the impression that you couldn't go over 6200-6300 rpm safely with the LE 1 cam, definetly didn't think you could go to 6500 rpm with a cam even bigger than the LE 1 cam? kinda interested in this, I wouldn't mind running a bigger cam on my LE 1 heads..
Old Nov 23, 2005 | 08:50 PM
  #39
96SilverRam's Avatar
Really good numbers !!
Old Nov 24, 2005 | 12:39 AM
  #40
JKDZ28's Avatar
Absolutly beautiful numbers man! Way to represent for the LT1 crowd!
Old Nov 24, 2005 | 08:49 AM
  #41
BlackScreaminMachine's Avatar
Just seeing promising numbers like that makes me feel very optimistic when I put my custom ground cam bret designed for me in my car!
Old Nov 24, 2005 | 10:55 AM
  #42
Yeah 11.7's or better aren't out of line if you setup everything right.
A 355 with stock LT1 castings is the way to go if you want to drag race.
He upgraded to the LE2 valvesprings, but yes the LE1 stuff is only good to 6200rpm
Bret
Old Nov 24, 2005 | 10:59 AM
  #43
Kryckter's Avatar
I had the LE2 Cam and LE1 heads in my 1997 Trans Am with all the same mods as the car we have been talking about. At sea level it went 11.7 @ 118 on motor. I never got a good nitrous pass, BUt it ran like 11.0 @ 12x spraying only first and second, Probably would have been good for a high 10 or a little faster at sea level. And this was on a 150 shot. I sprayed 200 on the setup also, But I had a forged 355.
I was very impressed by the setup and it ran very well. Anyone that does the setup will not be dissappointed.....
Joseph
Old Nov 24, 2005 | 12:27 PM
  #44
steven 95z's Avatar
great #s
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Russ95Z28
Apr 23, 2015 01:55 PM
racecarz28
Mar 30, 2015 09:55 PM
armedtrigger
Feb 24, 2015 08:30 PM
