le 1.5 track time
Old Jan 9, 2007 | 08:17 AM
  #31
1_badz28's Avatar
Originally Posted by METALBEAST
Would you be able to post of the complete slip info (60', 330' ET & MPH, 1/8 ET & MPH)? Thanks
yea i will get time slips this weekend , cause like i mention before we just opened the track up and we were testing the sensors, but forgot to connect the printer, so we were just going on what the computer said .
Old Jan 13, 2007 | 05:14 PM
  #32
1_badz28's Avatar
went this weekend 2 the track 2 get more passes on the car and got better results this time , best time of 12.088, at 111 mph, with a 1.6 60 ft. just wanted 2 know what u all think , btw this is a full weight car at about 3500 lb car and still going thru cat back, let me know thanxs josh
Old Jan 13, 2007 | 05:43 PM
  #33
Sweetred95ta's Avatar
MPH should be higher. You definitely still have some things to work out.
Old Jan 13, 2007 | 05:55 PM
  #34
1_badz28's Avatar
what do u think i should look at
Old Jan 14, 2007 | 10:24 AM
  #35
NightTrain66's Avatar
1.60 60 so the car launches hard.
Not sure what elevation you are at but if the elevation sucks, that will ba a lil MPH.
Other than that, Tq converter brand (Yank and Vigilante are whjt i would sugguest), converter lock up, rocker adjustment (1 /16 past zero lash), better tuning needed, fuel pump, etc, etc can all hurt MPH. Lots of things can cuse MPH to be low but for what ever reason, it is not seeing the MPH it should. I would think you should be OVER 114 MPH and closer to 116-117 MPH if at normal elevation.
Once you get it ironed out and see some better trap speed, the 1/4 ET's will come down also.
Old Jan 14, 2007 | 01:04 PM
  #36
I would say he should be happy with 114-115 in a stalled automatic car.
EDIT: You're right. I forgot he put down over 380 rwhp.
Old Jan 14, 2007 | 01:15 PM
  #37
METALBEAST's Avatar
So close to 11s! Congrats man! Looks like you will be there soon
Old Jan 14, 2007 | 01:27 PM
  #38
1_badz28's Avatar
the trq converter is just giving me 2200 to the footbrake . and also im still running on stock fuel pump .Btw lloyd this josh out of laredo tx. this setup is opening some eyes over here , thanxs and awsome, and another happy customer
Old Jan 14, 2007 | 01:32 PM
  #39
1_badz28's Avatar
thanxs man also the weather that day was really humid and about 70 degrees. so cooler weather and some weight reduction and we will b there , again thanxs 4 your comments
Old Jan 15, 2007 | 08:51 AM
  #40
hey, whats going on.
I was thiking you had a B/M converter, Did you ever swap to a Vig or yank that locks up more efficient up top?
I have had my best luck just leaving from an idle and tromping the gas off the line. I usually get 1.60-1.63 60 fts doing this (best is a 1.59) and the more I stall it, the worse the 60 fts get.
Old Jan 15, 2007 | 09:09 AM
  #41
Z-RATED94's Avatar
Lloyd, I forget, whos converter and what stall rating are you using? 1 badz28, those are some decent times and it looks like you still have more in it, once you tweak it.
Old Jan 15, 2007 | 11:36 AM
  #42
1_badz28's Avatar
I have a vig. and i got my 60 ft 2 a 1.6 of idle too. i also have the same problem if i stall it alittle . thanxs.
Old Jan 15, 2007 | 11:37 AM
  #43
1_badz28's Avatar
Thanxs man for the compliment
Old Jan 15, 2007 | 05:24 PM
  #44
Yank SS 3200 is what is in my car.
Foot brake is kinda misleading on "stall size" but just cruise around at 40-50 MPH or so in 3rd gear at 1400-1600 RPM and nail the gas for a second. The tach should jump up to 3000 RPM (or whatever the stall is) or so before it downshifts.
Mine shows about 3800 RPM by doing this but it is a 383 with a fatter TQ curve than most 350/355's and a HEAVY car (3820 lbs with me in it) sothe converter will stall and flash more than in a lighter car with less TQ.
Old Jan 15, 2007 | 08:47 PM
  #45
METALBEAST's Avatar
Something I don't recall anyone asking...what gear are you running? 3.23s? If so that could be a reason for the somewhat low trap. When I had my 92 Vette, I had More Performance ported heads, LT4 Hot Cam, shorties, Torkmaster 2400 stall, lid, K&N and cat back. I kept my 2.59s in the rear and the car would run a best of 12.90s@107-108 with 2.1 60's. Now, later when I sold the car to my buddy, we put some 3.73s in it. The the best trap speed LEAPED to 114.2 mph on a cold pass. He ended up running a 12.5@110 with a 1.86 60' hot lapping on a humid night.
At any rate my point is if you don't have some 3.73s or 4.10s that may be the last piece to the puzzle. If you do then...sorry I will shut up
