Largest cam with stock LT4 castings
Little background: Blew my motor yesterday. Heard nasty knocking before it croaked so i think the bottom end is toast. Had problem with dissapearing coolant, think it was drinking through a burnt head gasket or something. Anyhow its broke now, time for rebuild.
I found a shortblock that im gonna have freshened up, possibly bored to a 355. I think im decided on using some LT4 heads on the top end since they would be a bit cheaper then having my old LT1s worked.
MY QUESTION IS
What would be the biggest recommended cam that i could run on un touched LT4 heads.
MIND YOU THAT
1. I dont want to change valve springs so cam should not exceed maximum lift for LT4 springs. NOTE: i will be using 1.6 ratio rockers because im sure i will use them later once i DO get the heads worked.
2. Streetability is not a major issue because the car isnt driven all that much _but_ I do cruise down to carlsbad every once in a while (100 mile trip one way) and I would like to make the trip without tooooo much of a headache.
3. SMOG is not a concern either because somehow
my car always passes.
The car has a built 10 bolt rear end with TA cover, Toms axles, and 4.10 gears. Most likely will end up changing that out but ill wait for it to grenade before i do. AAA premium is nice
Sorry about the long winded post, and possibly sparking another dreaded cam debate.
I would greatly appreciate any knowledgeable feedback. I want to do this right and you guys are all fantastic at making recommendations.
Steve
97z Broke
MY QUESTION IS
What would be the biggest recommended cam that i could run on un touched LT4 heads.MIND YOU THAT
my car always passes.The car has a built 10 bolt rear end with TA cover, Toms axles, and 4.10 gears. Most likely will end up changing that out but ill wait for it to grenade before i do. AAA premium is nice
.Sorry about the long winded post, and possibly sparking another dreaded cam debate.
Steve
97z Broke
Re: Largest cam with stock LT4 castings
Ok i get it. I Read up some more, kinda posted before i should have. Seeing now that the LT4 springs are only good for .525 I suppose I SHOULD change the springs. Shouldnt be too much of a hassle since the heads wont be in the car or anything.
So please negate "MIND YOU THAT" #1 from my original posting, except the part about the 1.6rrs.
because i will be changing the springs. Thanks Bret.
Steve
Steve
3016-3037HR111+4 should work
230/236 XFI series 111 LSA 107 ICL (4* advance) .540/.536 with 1.5 rockers
Many people using the Xtreme XFI lobes?
