Large valve springs and head studs-clearance problems! pics!!
Old May 12, 2006 | 10:48 AM
  #16
Loadre's Avatar
Re: Large valve springs and head studs-clearance problems! pics!!
Grind the beyotch. I had to on mine. I was able to use a 6 point but we might be running different springs.
Old May 12, 2006 | 02:17 PM
  #17
Victory Racing's Avatar
Grinding sometimes has to be done on the middle washers on each head, when you are using larger OD springs. Grinding them as stated above is an acceptable method.
Depending on the spring, a thin wall 6pt should do the job.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
