Kooks LT1 Headers are great!
Old Apr 28, 2005 | 06:06 PM
  #61
WHYTLIE's Avatar
Re: Kooks LT1 Headers are great!
If it has the 3 bolt flange already on it, then obviously you can't use a clamp on there.
You are not being very descritive or clear on what you have parts wise.
I also do not recomend using a clamp on the collector since I have NEVER seen a clamp such as those seal tightly and with the O2 not being far from there, you can get some skewed readings off the O2's which will cause the pcm to compensate and screw up your tune.
BTW (to the Formula guy), I did realize you were being a smartass, but I was trying to provide all available information...
Old Apr 28, 2005 | 06:34 PM
  #62
blind527's Avatar
I don't know what I need...Do I just use the nuts/bolts that came with it to tighten it down? I wasn't sure if there is a better way. I haven't gotten the y pipe yet, but I have Jet Hot LT's.
Old Apr 28, 2005 | 06:51 PM
  #63
hatredizm's Avatar
Originally Posted by TCAL95Z
I think I have pics of everything. I will send them tonight to be hosted.
I'm still having problems with the steering shaft but I'm just going to have to take more off of the bolt that holds the two together.
Im in Mesa Az and was wondering how you installed the KOOKS on a dual cat car. Did you move/remove the cats and if so, how does this screw with the emissions laws around here man?
Old Apr 28, 2005 | 07:04 PM
  #64
94sinister's Avatar
Check out my cardomain at http://www.cardomain.com/id/94sinister for pics of Kook's headers with the clamps.(PAGES 5-6) Using clamps instead of a 3 bolt flange gives you better ground clearance.
For the guy in Mesa, AZ that's where I'm from. If you want to put long tubes on your dual-cat car you need to get a kook's y-pipe, have a custom y-pipe built, or you can go with true duals. AZ does have emissions, so you can run an offroad y-pipe until your emissions come and put some cat's on OR just have a custom y-pipe built with cats already on it.
Old Apr 28, 2005 | 07:29 PM
  #65
WHYTLIE's Avatar
It all depends on what type of Y-pipe you get. I believe the Jet Hot Y-pipe will have a matching 3 bolt triangle flange on the y-pipe ends and it might even come with bolts to attach them.
Otherwise, just go down to the hardware store and buy some grade 8 bolts, nuts and lock washers (or crown/lock nuts.) I usually get a 9/16" head which I believe is a 1/2 shank of the bolt. 1" or 1.5" long should be fine.
Also, the Copper ebossed SCE brand gaskets are great and I've never had an issue with them sealing.
Old Apr 28, 2005 | 07:35 PM
  #66
WHYTLIE's Avatar
Are the smog laws in Arizona more laxed then California and other states? Do they only do a sniffer test, no visual inspection?
Because moving the cats at ALL fails visual inspection. And removing or replacing the cats before 50,000 miles (if cats are not damaged) is illegal as well.
The Kooks cannot be used for a "technical" smog legal car. I'm sure you can pass smog with Kooks on in some states/shops though.
Old Apr 28, 2005 | 07:57 PM
  #67
94sinister's Avatar
I'm pretty sure that there is no visual inspection. I've been told that they are very lax anyways. A member of the AZFBA even passed the sniffer with no cats and an aftermarket cam (LS1) on a very good tune.
Old Apr 28, 2005 | 09:02 PM
  #68
WHYTLIE's Avatar
Wow, I'm jealous... folks out here are being sent to the smog ref for stupid things as painted valve covers and polished brake/ac lines.
Most of them are ricers, but still...
Old Apr 29, 2005 | 09:44 AM
  #69
hatredizm's Avatar
I'd like to meet up with you one day man and check out your car. I'm wanting LT's but dont want to hassle with the morons thinking my car would do more damage than all the busses out here do. Would also be nice to get a few ideas of how they are ran.
Old Jul 5, 2005 | 08:11 AM
  #70
CamaroGuy22's Avatar
Did the original poster ever get dyno results?
Old Jul 5, 2005 | 06:17 PM
  #71
Houdini's Avatar
I will be going to the dyno this friday so I should have some before and after results for you. My cars best dyno numbers before the headers are in my sig, nothing has been changed since then except the wheel/tire combo. I will get a base run with the dual cut-outs closed and then one with them open, after that I start the tuning to see if I can gain any more.
birdblack
Dec 30, 2014 06:59 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
