Kook's Headers. Easy Install?
Old Oct 21, 2005 | 07:35 PM
Harvey's Avatar
Question Kook's Headers. Easy Install?
I have two questions. I have the heads and intake off right now doing a head gasket job. And, of course, the dumb stock manifolds. Now, the question is have I already done the hardest part in a Kook's header installation or is the hard part installing the headers? I would THINK the header would be harder to install, but I was just looking for a concences. The second question is can this be done using jack stands in your garage or would this really need the use of a lift? Obviously, a lift would be easier, but how hard is it with jack stands?
I don't have them yet, but am looking at getting the 1 3/4" to 1 7/8" to 3".
Wayne
Old Oct 21, 2005 | 07:41 PM
CamaroSS30thAnn's Avatar
Re: Kook's Headers. Easy Install?
i did mine on my back and i would say the only time u need teh car really high is to get the driver side header in ,u need ot get teh car pretty high but its do-able
Old Oct 21, 2005 | 07:46 PM
Harvey's Avatar
CamaroSS30thAnn, one thing I forgot to ask do you have a stock k-member? CANTONRACER has the headers and said he couldn't tell me really how hard it would be on mine because he had a tubular k-member. And I thought the driver side would be the easier of the two, more room on that side. That manifold came out real quick, I had all kinds of problems with the passanger side. CamaroSS30thAnn, didn't have to jack with the motor mounts?
Wayne
Old Oct 21, 2005 | 08:14 PM
on my car the passenger side was the easeir to go in but the hardest to bolt up
i have a stock K member
teh driver side should be easy to get in but u have to get the car way high in the air b/c u have to put the header in at almost a straight up angle (collector facing teh ground)so u have to get the car up really high
it wasnt reccomended to jack teh motor but i did take teh mounts off and did jack the motor so id idnt run into any problems
edit: ask me anything i hasnt been to long since i did these and its still mostly clear in my head
Old Oct 22, 2005 | 12:16 AM
1racerdude's Avatar
If ya have the heads off,just slip the headers in the chassis and wire them back enough to get the heads back on. Ya may have to take the steering shaft off and maybe the starter and put it on stand's pretty high. That should be all there is to it.
Old Oct 22, 2005 | 01:22 AM
whoops didnt realize u had teh heads off, hell that makes it twice as easy , thats if u still have them off,
u can slip them dwon prolly from teh top and then make sure they are clear and out teh heads back on and then bolt em down
steering shaft and starter are almost a must to have to come off
Old Oct 22, 2005 | 09:49 PM
Harvey's Avatar
After I take the starter and steering shaft off, how hard is it to get them back in with the headers in place?
Wayne
Old Oct 22, 2005 | 09:57 PM
1racerdude's Avatar
Wayne
Not hard at all.
Old Oct 23, 2005 | 02:00 AM
Wayne
the starter just bolts right back up and the steering shaft slides right in , for some reason i had a little trouble with my steering shaft but with a little umph and wiggling it went right in
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
Queens94z28
Mar 23, 2015 08:06 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
