knocking at mid rpms
Old Aug 6, 2008 | 10:22 PM
x24-7x's Avatar
1995 firebird. LT1. Headers,exhaust,K&N FIPK,Spec3 clutch.
So i was somewhat getting on it earlier and my car had seemed sluggish about an hour before this..so i got on it..and when i let off it died. So it started right back up. I pull over to discover a knock at mid rpms. It also seems hard/takes a little longer to start. But at an idle, or high rpms, the knock seems to go away. But it runs sluggish now. Any ideas? Should i tighten the valves? Or could it be a bent rushrod? Or could it be a rod wanting to leave my motor? There is a lot of possibilities i know but does anybody have any ideas??
Old Aug 7, 2008 | 01:11 AM
x24-7x's Avatar
id like to have it fixed by tomorrow night so any help would be appreciated
Old Aug 7, 2008 | 09:30 AM
x24-7x's Avatar
im checked the driver side valves and they seemed fine. im gonna do the passenger here soon which is where it seems more to be coming from. almost sounds like its above the water pump though..
Old Aug 7, 2008 | 09:34 AM
JoeliusZ28's Avatar
if you could get a video with some good sound on youtube that would help.
Sounds like it might be a lifter, although thats just a stab in the dark.
Old Aug 7, 2008 | 10:31 AM
x24-7x's Avatar
I just tried to. But with all of the other noises you cant really hear anything. It sounds like a woodpecker almost. ha. But it only does it when reved around lower to mid rpms.
BTW my lifters are brand new so..
Old Aug 7, 2008 | 01:42 PM
x24-7x's Avatar
ideas?
Old Aug 7, 2008 | 11:11 PM
x24-7x's Avatar
Earlier i started it..and then it cut off a few seconds later..then started it and turned it off..then went to start it and had to pump the gas to get it to start then ran. Can anybody help me at all? Iv found some used lt1 blocks for 200-500 dollars so if it comes down to it thats what ill do..if its like a spun bearing..which is what it seems to be..but any ideas? Anyone? Im ready to blow it up!!!
Old Aug 8, 2008 | 01:04 AM
mrmint69's Avatar
If you removed the valve covers and could not pin point the noise it might be something internal and not valve train related. I would try to find exactly where the noise is coming from and go from there. If you just did some work on the car then something might be loose or adjusted incorrectly.
Old Aug 8, 2008 | 05:19 PM
x24-7x's Avatar
im thinking its a spun bearing. i think i may go ahead and get a fully forged 383 short block
KYWes
Jun 14, 2022 06:52 AM
Xiantyl
Jul 21, 2015 05:42 AM
GT what?
Jul 14, 2015 10:17 PM
asilomar244
Jul 12, 2015 05:53 AM
birdblack
Jul 8, 2015 07:23 AM
